AATranslator jetzt mit AAF-Import
  • Ersteller Ersteller suboptional
suboptional
Gesperrter User
http://www.aatranslator.com.au/
Wohl das beste DAW-Projekte Conversion-Tool.
Version 5.4.0
* AAF Import: Now available in the 'enhanced' version
* AAF Import: AAFs from PT7-9, Vegas, Nuendo, Logic and STP are initially supported
* FCP-X (fcpxml) Import: Now available to both 'standard' and 'enhanced' versions
* OMF Import: Fixed zero length clips/regions which caused most daws to crash - size set to 1 sample
* VIP Import: Fixed error in clip sizes where xfades were present
* VIP Import: Fixed error of missing clips caused by track fx
* VIP Import: Added track pan and track gain where track automation not present
* PTF Import: Fixed error with very lengthy tick based tracks
* PTF Import: PT10 PTF files saved as PT v7-v9 fixed another variant from PT10 v10.1.2
* PTF Import: Improvements in converting clips/regions on 'tick' based tracks.
* PTF Import: Fixed strange overlapping clips without fades - previously missed the last clip on the track now fixed
* PTF Import: Now converts SOME 'region groups' with clip group status converting to formats like Reaper, SES, SESX, etc
Region groups within region groups are not supported – as a general rule region groups should be avoided
* PTF Import: Fixed error reading BPM in version 9 PTFs
* PTS Import: Improvements in converting version 5.1 session files
* PTS Import: Improved reading of media from Mac files without a file extension
* PTS & PTF Import: Fixed an obscure RT6 error involving markers/cues
* FCP XML Export: Markers can be no closer than one frame. Some markers may be removed during conversion
* FCP XML Export: Remove '&' from marker names and description. Replaced with '+'
* SESX Import: Fixed run-time error reading markers
* Nuendo/Cubase Export: Mono tracks are now created for mono files and stereo tracks for stereo files
* Nuendo/Cubase Export: Issues with the odd audio not showing in the clip now resolved
* Nuendo/Cubase XML Import: Fixed Track Automation sometimes not read properly from Group Folder Tracks
* Nuendo/Cubase XML Import: Now convert routing for group channels/sub groups
* Nuendo/Cubase XML Import: Fixed Bus names
* Nuendo/Cubase XML Import: Now read 'Cycle Markers'
* Nuendo/Cubase XML Export: Issues with sessions containing mp3s now fixed
* SESX & SES Export from Nuendo: Fixed clip envelopes set to infinity
* OMF Import: Fixed errors associating audio with clips from 'Diaquest PPro4 OMF Converter'
* Vegas XML Export: Fixed invalid bus details causing Vegas to fail to load XML
* Vegas XML Export: fixed errors caused by track automation points less than zero
* OpenTL Export: Issues with sessions containing mp3s now fixed
* OpenTL Import: Now check for existence of SD2 files before trying to convert to wav files
* Export to Capture: Fixed issues with sessions containing mp3s. Mp3s now renamed as wav files
* Ableton Export: Ableton requires bpm - now defaults to 120bpm
* Convert AIF to WAV: Fixed a recently introduced error causing wav file to not load in some daws
* The 'Use This Session File as a Template' option is now saved on exit
As you can see we have added AAF import (for the ‘enhanced’ version) but we have found this format to be a hit or miss affair when it comes to DAWS reading AAFs from other DAWs.
So we have initially concentrated our efforts on AAFs from PT7-9, Vegas, Nuendo, Logic and STP.
We have also added the ability to read FCP-X (fcpxml) and made it available to all users. This is the first step with this format (a format which has no concept of ‘tracks’) and we expect to be building on our efforts in future releases.
(nur zur Sicherheit: Ich habe nichts mit der Firma zu tun. Aber ich habe es in Benutzung und finde es ein sehr gutes Produkt und die Entwickler sind auch sehr kooperativ falls mal Probleme auftauchen sollten).
Reaktionen: kickback
