oati
Individualist
Das ging ja fix.
Unschön.
Ich glaube nicht, dass NI da nachbessern wird.
Na ja, die Hoffnung stirbt zuletzt.
Saving a project takes an unexpected long time when using VST instruments with sample-based content libraries, e.g. with Native Instruments Kontakt.
In general save times will increase the more instances of instruments and sample -based content is involved. However, save times can increase unexpectedly the more instances of NI Kontakt are actively in use and depends on the scope and size of content libraries you use there within a project. Please contact the plug-in manufacturer for a solution. To decrease project save time consider rendering tracks and removing instances of the instruments afterward.
Bei mir dauert es nicht länger als in 8.5.Unschön.
Oh.
Ich hab ja bis jetzt die 9.5 noch gar nicht installiert
D.h. damit sollte ich auch warten oder was? Große Kontakt-Projekte dauern jetzt ewig zu speichern?
da hamma wieder den Salat:In general save times will increase the more instances of instruments and sample -based content is involved. However, save times can increase unexpectedly the more instances of NI Kontakt are actively in use and depends on the scope and size of content libraries you use there within a project. Please contact the plug-in manufacturer for a solution. To decrease project save time consider rendering tracks and removing instances of the instruments afterward.
So habe ich das nach eigenen Tests seit Jahr und Tag ebenfalls gepflegt zu tun.da hamma wieder den Salat:In general save times will increase the more instances of instruments and sample -based content is involved. However, save times can increase unexpectedly the more instances of NI Kontakt are actively in use and depends on the scope and size of content libraries you use there within a project. Please contact the plug-in manufacturer for a solution. To decrease project save time consider rendering tracks and removing instances of the instruments afterward.
geht der tsching bei Musotalk her und empfiehlt statt Multi für jedes eine eigene Kontakt-Instanz und schon kommt da das oben gepostete von Steinberg raus
(gestern noch gesehen, also ich mir die MusoTalkshow zu 9 reinzog)
Von “meinen” Bugs wurde auch nichts behoben.
Da ist schon noch sehr viel zu reparieren. Es wurde wohl, wie immer, unter starkem Zeitdruck gearbeitet.
Hast du deine Bugs irgendwo dokumentiert? So rein aus Interesse worum es dabei geht. Danke.
Ich glaube im deutschen Forum liest kein Mitarbeiter mit, höchstens mal der Mod, wenn dann im englischen Forum unter issues.in der deutschen Abteilung, weil ich gehofft hatte, die deutschen Steinberg-Angestellten würden dort am ehesten nachsehen
Ja, im Steinbergforum (in der deutschen Abteilung, weil ich gehofft hatte, die deutschen Steinberg-Angestellten würden dort am ehesten nachsehen).
kann ich bestätigenIch glaube im deutschen Forum liest kein Mitarbeiter mit, höchstens mal der Mod, wenn dann im englischen Forum unter issues.in der deutschen Abteilung, weil ich gehofft hatte, die deutschen Steinberg-Angestellten würden dort am ehesten nachsehen
Dort schreiben auch die deutschen Angestellten ab und an.
