Youlean Loudness Meter V2.4.3 [FREE]
mkzwoo
Loudness-Opfer
Darf natürlich auch nicht fehlen, finde eines der besten Free Loudness Meter überhaupt... Ist momentan auch im Sale, falls wer die Pro Version haben möchte...
The Youlean Loudness Meter 2 is a free loudness meter plug-in and unlike some other free loudness meter plug-ins runs on macOS and Windows and supports AAX, VST and AU plug-in formats.
What Youlean Say About Their Loudness Meter Plug-in​
  • Works in almost any DAW - Available in VST2, VST3, AU and AAX plugin formats, Windows and macOS operating systems, Apple Silicon compatible.
  • Helps you comply with strict loudness requirements for the Film and TV industry.
  • Helps you get the correct loudness levels for upload to Spotify, YouTube, Apple Music and Tidal.
  • Find out what regulation your country is using and use ITU-R BS.1770-4, EBU R128, ATSC A/85, OP-59, ARIB TR-B32 or AGCOM 219/09/CSP preset to comply with the standard.
  • Make sure to sound great on Spotify, YouTube, Apple Music, Tidal or when streaming by using AES loudness preset.
  • GUI too small or too large? No problem, freely resize or scale the plug-in
  • If you find graphs too distracting you can always switch to mini mode. Fit precisely for your workflow.
  • Inspect what exactly is going on with the audio dynamic. Using the peak to short-term loudness algorithm you can detect squashed or not correctly compressed mix.
Free Version
  • Film, TV and Gaming presets
  • LU, INT, TP, LRA, PLR, DR readouts
  • Resizing, scaling GUI
  • Mini view
  • Custom true peak alert threshold
  • True peak and loudness graph
  • Loudness distribution graph
  • Automatic loudness overdub
  • Mono, Stereo, and 5.1 channel
  • Low CPU consumption
  • Never expires
Windows – V2.4.3, macOS – V2.4.4
Wenn mich nicht alles täuscht, hat diese Version mit Werbung für die Pro Version tierisch genervt, deswegen hatte ich mir dann die Beta geladen, die ohne sowas auskommt. Gibt aber auch inzwischen genügend Alternativen.
Hier dann auch mal ein kleines Update... Version 2.5.6 RC1...
Changelog:
V2.5.6 – December 29, 2023
Fixed broken GUI text in drag & drop when GPU acceleration is off
Fixed GUI lag when overwriting measurements in Pro Tools
Fixed crash in auval tool on macOS
Fixed crash with VST3 in Reaper on macOS
Fixed audio output broken in Audacity with VST3
Fixed top and bottom bars not hiding after project reload
Updated CSV export file to include all measurements
It is no longer mandatory to use “–export” for exporting in the command line tool
You can now use “–preset-import-path” to import a preset from a custom location via the command line
Various small fixes and stability improvements
Reaktionen: adl
Youlean ist jetzt in der finalen Version erschienen, nach einer ewig langen Beta:
Außerdem geradem im 45% off sale bis 02.12.
Anbei mal der Changelog seit dem letzten hier geposteten. Der Mann war echt fleißig
V2.5.10 – November 9, 2024
  • Fixed graph memory not saving correctly
  • Fixed utf8 characters not showing correctly in file names on Windows
  • Fixed meter hidden when external monitor is disconnected
  • Fixed file browse multimono crash
  • Fixed clipped text when moving with hardware acceleration off
  • Fixed crash when changing default OS audio device with standalone app
  • Fixed broken chars in Windows App settings
  • Fixed app will reset its settings if you quit via app menu a couple of times in a row
  • Fixed AAE: -20038 error in Pro Tools
  • App will now remember its position on the screen
  • Added resizing from all sides of the window for App on Windows
  • Removed meter interface is larger than the monitor warning
  • macOS 10.13 is now minimum requirement
  • Various small fixes
V2.5.9 – October 3, 2024
  • Fixed default settings do not load correctly with VST3 in some DAWs
  • Saving app session and dark theme settings are now global
  • Updated handling AAX IDs for a possible final fix for -20038 error in Pro Tools
V2.5.8 – September 26, 2024
  • Fixed crash when changing audio inputs in standalone APP
  • Fixed not being able to change audio device in the standalone APP on macOS 14.1 or earlier
  • Fixed normalized file name unicode error on Windows
  • Fixed GPU acceleration can not be disabled in some cases
  • Fixed overdubbing with Time Code mode not showing the right part of the graph
  • Added a popup button to update all presets when you change some parameters
  • The app will automatically reset audio input settings if it detects that it has crashed repeatedly
V2.5.7 – September 13, 2024
  • Fixed uppercase letters in the file extension not recognized correctly when analyzing a file
  • Fixed normalization not working for FLAC files
  • Fixed normalization not working correctly for files bigger than 4GB
  • Fixed graph glitches when framerate drops while overwriting in the time code mode
  • Fixed macOS scaling using CTLR instead of COMMAND key
  • Fixed crash in Qlab 5 on macOS
  • Fixed app won’t scale correctly on Windows when moving between monitors with different DPI
  • Fixed the “GUI will not fit” warning wrongly showing when using vertical monitors
  • Fixed AAX plugin doesn’t load in Avid Media Composer
  • Fixed AAX AAE: -20038 error in Pro Tools
  • Fixed graphical glitch when graphs are updating
  • Fixed compatibility with older project files
  • Added “–unregister-license” option to unregister license from the command line tool
  • Added more graph window sizes between 1h and 4h
  • Added option to double click and edit window size. Use: 01:15:53, or 1h 15m 53s notation. If time is not specified, it will be treated as minutes
  • Added option to auto update graph window size from the input audio length
  • Added default audio device option for input and output in the standalone app
  • Added option to reverse mouse wheel zooming direction
  • Added peak meter scale options
  • Added option to analyze system audio natively on macOS 14.2 and later
  • Added license info panel in registration menu
  • Added “Reset All Settings” button in the help menu
  • Updated the handling of global settings
  • Presets now save all settings, including text scaling etc.
  • Graph saving option no longer requires PRO version
  • Improved project saving speed and reduced project file size
  • Improved Audio Unit stability
  • Reversed direction of mouse wheel graph zooming
  • Windows app when analyzing system audio will auto switch audio devices if the default device is changed
  • Switched normalization WAV format for files bigger than 4GB from W64 to RF64 for better compatibility
  • Increased maximum file analysis time to 5965 hours (tested up to 150 hours)
  • Input file is not required anymore to register the license in the command line tool
  • App will now always start centered on the screen in order to prevent it from being off-screen in multi monitor setups
  • Various small fixes and stability improvements
Cool. Die VST3-Version bringt umgehend die gesamte DAW zum Absturz (REAPER bei mir). Reproduzierbar. Die VST2 ging aber. Nach der erneuten Installation (diesmal nur VST2, um den Crash zu vermeiden) stürzt aber auch die VST2 ab. Schade, aber fliegt raus.
In Reaper gibt es doch bereits ein vergleichbares Tool.
Reaktionen: sts
Alles gut, ich vermisse nichts. Außer vielleicht ... ach, lassen wir das, es gehört nicht in dieses Forum.
Ich hab das youlean Meter früher auch verwendet. Aber Reaper hat in den letzten Jahren massiv zugelegt. V.a. unter den JS Plugins gibt es ein paar richtige Perlen. Das Loudness Meter Peak/RMS/LUFS macht auch nichts anderes.
Reaktionen: sts
Läuft bei mir absolut ohne Probleme. Finds ne verdammt zackige GUI, ist jetzt VST3 auf Macbook.
Ist ja gut so. Ich mag mich aber mit so etwas nicht mehr rumschlagen, sofern es kein unerlässliches (oder teures) VST ist. Ist mir zu mühsam und langatmig - was auch immer am Ende die Ursache ist. Will ja gelegentlich auch mal Musik machen, statt störrische VSTs zu verarzten. ;)
