WaveLab 6.1 Update ist da!
Bergneustadt
Hallo Freunde,
ab sofort steht bei Steinberg für alle WaveLab 6 User das Update auf 6.1 zum kostenlosen Download bereit!
http://www.steinberg.net/539_1.html
thx, gleich gesaugt und draufgepappt!
LG,
Soares
Kann das irgendwas? Ausser funktionieren.
Top 3 der Topfeatures bitte! (komm von hier aus nicht auf die Seite! :doh: )
Ari
Ref. = http://www.steinberg.net/539_1.html
Improvements
Podcast creator. This is a rather large feature, please refer to the addendum documentation.
Better optimizations for Intel Core 2 Duo processors.
Batch processor: new « Audio Injector » [g=8]plugin[/g]. This [g=8]plugin[/g] allows to [g=84]insert[/g] an audio file before or/and after the files to process, with an optional cross-fade process. The file(s) to inject must have the same number of channels and sample rates as the source files, and must not be longer that 60 seconds.
Batch processor: new « Trimmer » [g=8]plugin[/g]. This [g=8]plugin[/g] allows to cut a specific time at the head or/and tail of the audio file. It can be useful when combined with the Silence plugins, Fade-in/out plugins, and reverb-like plugins.
Waves [g=77]VST[/g] plugins are now supported from the Master Section (must be using the latest [g=77]VST[/g] shell).
Audio Montage: it is now possible to navigate in the zoom/cursor/scroll history using the more standard key shortcuts Alt+Left/Right arrow keys. Some extended keyboards have dedicated keys for this. Same thing for mouse Back/Forward buttons (mouses with 2 additional buttons on the side). In other words, it is possible to navigate in the zoom/cursor/scroll history using the same shortcuts as eg. in Microsoft internet explorer.
Audio Montage: better display when using Control + left/right arrow (allow to navigate from clip boundary to clip boundary).
Audio Montage / Wave : Key shortcut added for « Move edit cursor to position... » : < ! >
Key shortcut added for « Live input... » : < Control + Shift + I >
Bug fixes
Crytal Resampler: bug fix and slightly improved quality in « Ultra » mode.
Burning an Audio Montage using Track effects, and with the option « Render to temporary file before burning », had for effect to apply the track effects twice.
[g=420]CD[/g]-Text issue fixed.
When moving a Xfade left and right, the volume enveloppe points don't move anymore.
Improved look and installation under Vista.
Problem fixed with some plugins used with a mono file.
Audio [g=420]CD[/g] grabbing: the last audio track of a [g=420]CD[/g]-Extra could not be grabbed and its length was wrongly displayed.
Opening the Live Input window while a meter window was open, caused a crash.
Recording audio to a mono track of an Audio Montage, was systematically adding a new track to the montage.
Fixed problem that could happen when exporting text in Excel format (eg. Clip list)
Audio Montage: playback can now start even if some audio [g=357]peak[/g] files are being built.
Improved compatibility when saving « ulaw » and « alaw » audio files with a WAV file header.
In the montage "Files" tab, the file date's day and month were exchanged.
It was not possible to erase a Montage track name.
Batch renaming of clips and markers: the initial value of the « counter » procedure was ignored.
Useless [g=357]peak[/g] files with a null size could sometimes be created for some audio files.
Auto Split: useless audio files with a null size could be created, in certain cases.
Master Section slot key commands above 3 where not selectable.
Auto Split: in mode « Cut Head and Tail », the option « [g=84]Insert[/g] silence at start or end » was ignored.
Silence [g=8]plugin[/g]: (batch processor). The [g=8]plugin[/g] works nice correctly.
Loudness distribution: the dB value displayed at the mouse cursor position, did not take into account the AES17 preference.
Opening a copy of an Audio Montage, would change the date of the original montage.
Audio file path is now remembered when opening an audio file as a montage.
Audio Montage: saving a clip will now always set the right file extension (« clip »).
Audio Montage: the colour condition feature was not working.
Other minor problems.
Nach einem ersten kurzen start würde ich sagen: sie haben gut daran getan, es nicht wavelab 7 zu nennen ;)
aber es läuft stabil.
bis auf die podcast und diverse fixes im [g=8]plugin[/g]-betrieb eher ein "UPDATEchen", aber immerhin.
LG,
Soares
