WaveLab 10 kommt!
Aus dem engl. Wavelab-Forum:
WaveLab 10 comes with the broadest range of new features and improvements, among them major enhancements, that have ever been released in it's product history:
Reference track A/B
Allows you to add a reference audio file and switch playback between the reference track and the montage tracks
Video support
Video file playback in the Audio Montage, allowing you to arrange, edit and process the audio of a video
Extended external effects support
Using a combination of outputs (sends) and inputs (returns) on your audio hardware, you can use external effects
in the Audio Montage as Clip, Track and Output effects.
External Editor support
You can now integrate other audio editors (like SpectraLayers or Izotope RX) into your WaveLab workflow!
Undo/Redo history for Audio Editor
Available in the Audio Montage and — for the first time — the Audio Editor workspaces, both have their own independent undo/redo log.
Montage Inspector
The handling of plug-ins and corresponding functionality — like channel processing, signal routing, loading effect etc.
is now streamlined and consistent between the Master Section and the new Montage Inspector.
Audio Montage track list overhaul
The different track types (Audio, Reference and Video) have a new track header design with dedicated controls for each track type.
Live Input Stream recording
WaveLab 10 allows you to record and render live input streams through the Master Section and the inserted plug-in chain.
Audio Montage Inline Editing
Let's you open a clip range in the Waveform or Spectrum Editor and edit it non-destructively.
Enhanced Preview in File Browser
The File Browser window and the Audio Files File Browser now allow you to jump to a specific play position inside a preview file.
New audio settings and routing options
WaveLab 10 comprises an enhanced audio I/O routing system.
Performance monitor
WaveLab 10 comes with a new performance monitoring meter showing the average audio processing load of your WaveLab session.
New plug-ins
Frequency EQ, REVelation Reverb and Magneto 2 have been added to the WaveLab plug-in feature set.
Multitrack Recording
Let's you record multiple track at once in the Audio Montage.
Marker support
Now available for imports from XML file.
Master Section enhancements
Increased amount of effects and playback processing slots.
Rendering enhancements
Real-time rendering with audition.
More improvements
Improved third-party VST plug-in support, improved playback performance, Marker List and CD List follow playback indicator
Ich weiss nicht, wozu man das Programm als Cubase Nutzer braucht. Außer DDP. Feature Liste ist auch wenig beeindruckend. REVelation Reverb und Magento 2 übernommen, haha, na Holla, die Waldfee! :D Ich habs auch, vollkommen überflüssig, meistens. Außer für DDP und irgendeine Wave Manipulation als Audio Editor. Wer wird denn Video damit bearbeiten wollen ...
Leider ist die Einbindung externer Editoren auf WL Pro beschränkt, wenn ich das richtig gesehen habe.
Hatte mich schon immer gefragt, was man da überhaupt noch groß verbessern könnte.
Hüstl ... WaveLab ist ein Feature-Grab, vieles an Bord, teilweise unbedienbar, bzw. wenig intuitiv oder mit einer gehörigen Portion Eigenleben. Als da sind Projekt-Handling, Austauschbarkeit von Files in einer Montage nur mit Einschränkungen, Mehrspuraufnahme unnötig kompliziert,
Ha! da sind sie ja... gefunden: (ohne sie bisher angeschaut zu haben)
Das sind aber keine neuen Features, oder?
Das Update lasse ich mal aus.
Update von WL 9.5 für 79,99 €!
Was..? da bin ich mit dabei!
Jetzt bin ich aber ein wenig Konfuzius!?o_O
Hast Du nicht vor wenigen Tage gesagt, Du masters alles in Cubase und so etwas wie eine Projektpage wie in Studio One braucht man nicht!?...wozu dann Wavelab?
Aber egal,...schade, ich habe damit gerechnet das Wavelab am 13. November mit in Cubase 10.5 integriert ist!:(
Reference track A/B
Video support
Montage Inspector
Performance monitor
New plug-ins
Marker support
More improvements
Für Cubase Benutzer: WaveLab Pro kann meiner Meinung beim Mastering mit diversen Tools (z,B. MasterRig und RestoreRig ) und seinem übersichtlichen Workflow helfen.
Das seit 9.5 vorhandene Inpaint Tool zum Beispiel verwende ich relativ oft (siehe unten im Video).
Was ich bei der neuen Version nützlich finde ist die verbesserte Möglichkeit um Hardware via externe FX-Busse in das Mastering zu integrieren. Das gehört definitiv für mich zu einem der wichtigsten Gründe um das Update auf die 10er Version zu erwerben.
Auf die neue Versionsverwaltung bin ich ebenfalls gespannt.
Neu gibt es zudem Mehrkanal - Recording Funktionen, auch das muss ich zuerst ausprobieren und mir die Vorzüge gegenüber Cubase ausloten. ...
Und endlich gibt es wieder einmal "einen Steinberg" der bereits bei seiner Veröffentlichung mit deutschem PDF ausgeliefert wird :popcorn:, wo auch die Neuigkeiten zum schnellen Querlesen oben aufgelistet sind. Ausserdem ist auch die Plugin Referenz bereits auf Deutsch erhältlich.
https://steinberg.help/wavelab-manuals/wavelab-pro/wavelab-pro-10/
Reaktionen: markrec und triangle
.wozu dann Wavelab?
Habe hin und wieder Restaurationsaufträge; Mehrkanalaudiozeugediting oder für Sampleerstellungen. Wavelab ist schließlich nicht nur zum Mastern da. Und wenn ich mal eine CD als DDP rausgebe. Letzteres kommt selten vor heutzutage.
Natürlich mastere ich wohl zu 92 und mehr Prozent in Cubase, weil es eben bequem dort geht. Aber WL update ich immer wieder gern, paar Sachen sind nun mal einzigartig. Du brauchst es nicht. ^^
Wozu.
Heutzutage braucht kaum noch einer eine Montage oder Projektpage - alles kann man bequem direkt im Arrange mit Plugins mastern. Songs werden auch nicht mehr auf CD gebrannt, sie werden direkt hochgeladen, einzeln. Hatten wir schon das Thema.
Da wird Steinberg sowieso keine Ressourcen verschenken, da kannst du sicher sein und das Beten aufgeben - zumal es völlig unterschiedliche Programme mit komplett unterschiedlichem Code sind. Das kann man nicht eben mal so zusammenführen, nur weil man es sich vorstellen kann. Da müsste man schon einen neue DAW bauen. Und das wird nicht passieren, weil extrem Zeit und super kostenintensiv. Finde es gut, wie es ist, separate Programme.
WL ist heutzutage eher Nieschenprodukt, das ist wahr.
Macht euch also keinen Kopf drum und überlest diese Release-Infos einfach...
Reaktionen: NorthernDecay
Klar. :D Typische Aussage eines Seltennutzers. Ein Kommentar hierzu verkneife ich mir. ;)
Und wir meckern und dissen die Tage mal nicht - es ist immer gut, wenn´s weiter geht mit einer Software... Nicht jeder braucht WL.
Wir hatten es schon vor 10 Jahren gut genug mit unseren DAWs. Ironie off.
Reaktionen: triangle, LuMar und Glutamatjunkie
So, neue Videos zu den Features in WL 10... doch viel mehr neue und nützliche Dinge als ich anfangs dachte!
Reaktionen: markrec, Vast und Gast92251
@LuMar : Danke fürs Posten! Die waren gestern noch nicht online, oder? cooler Stuff...
Überlege gerade...mit den neuen Videofunktionen, ob ich WL für Voice Over Projekte nutze könnte...
Reaktionen: Gast92251
Hmm... mit der Videospur und dem "Live Input Rendering" sollte das doch gehen.
Und dann kann man das erzeugte File ja wunderbar in der Montage an die Videospur anpassen/feinjustieren!
Hallo zusammen, nochmal 3 neue Feature-Videos von WL 10:
Reaktionen: markrec und Gast92251
Also alleine die neue Undo/Redo History und die Einbindung externer Editoren sind mir ja die 79,99 € Upgrade-Preis wert! :)
