Wartungsupdate 11.0.30
  • Ersteller Ersteller microm
microm
microm
Das Wartungsupdate 11.0.30 ist da.
Reaktionen: kerninger, Gast92251, terrablue und eine weitere Person
CUBASE 11.0.30
What's new?
June 24, 2021 – Cubase 11.0.30 comes with several fixes and improvements.
Please download and install the Cubase 11.0.20 core application in the Steinberg Download Assistant, which should already be installed on your system. If not, you can find it here.
As always, your feedback is highly appreciated, so please let us know what you think about the 11.0.30 update in our community forum.
WE HAVE CORRECTED THE FOLLOWING FEATURES AND FUNCTIONALITIES
MIDI
Data in the controller lane for program change events is now displayed consistently with the info line (from 1-128).
MIDI notes are no longer missing in exported MIDI files when MIDI parts use Velocity on the info line to subtract values.
Using MIDI step input no longer creates hanging notes with external MIDI instruments.
SysEx data no longer interferes with MIDI recordings when received in pre-count phase (affects e.g. ROLI devices).
MixConsole
The on/off state of the Pre filter section is now stored in the Pre filter presets.
The link of a send panner to the channel panner now works correctly when send destinations have a different format.
Switching faders/inserts/sends in the MixConsole in the lower zone no longer leads to unexpected scrolling positions.
Miscellaneous
In macOS, the Direct Offline Processing user interface no longer turns red sporadically after a period of extensive operations.
When using Direct Offline Processing, Time Stretch on audio files with a sample rate other that 44.1 kHz no longer creates artefacts when auditioning.
It is now possible to trigger macros via key commands when the Process Bars dialog is open.
Using modifier keys no longer fails when editing in Windows 10 (e.g. Alt-drag for duplicate).
Acoustic feedback is now working correctly when clicking on a scale event.
Changes made in an ARA extension editor are now restored correctly when the operation is undone and then redone.
Switching between track versions no longer resets ARA extension settings.
Overwriting existing audio mixdown files no longer creates files with the wrong length in macOS.
When executing a job queue in Export Audio Mixdown, an incorrect error message about missing cycle markers is no longer displayed.
Note names in the Inspector for expression maps are now shown correctly.
Importing a track archive that references multiple audio files of the same name now works as expected.
Using the Project Logical Editor to enable/disable Track Operation: Inserts Bypass is now working for all track types, e.g. instrument tracks.
It is possible to add additional lines for Logical in the Filters area again.
The user interface of FabFilter plug-ins is now displayed correctly on screens with 21:9 ratio and 125% or 175% Windows scaling.
The project cursor no longer changes to a thin line in Windows 10.
Toggling Record Enable no longer interrupts the audio output when a project is playing under heavy CPU load.
A maximised Project window now remains maximised when working with sampler tracks in Windows 10.
Using Undo in the Score Editor no longer closes the editor window when Show Chord Track is activated and the chord track has Lock enabled.
Several window focus issues have been resolved when switching back and forth with other applications in Windows 10.
Several graphical issues in SuperVision have been resolved.
The Low-Cut parameter in the Delay Character section of the MultiTap Delay is now working correctly when a delay module is used for effects.
Stability
We have improved the stability in several areas of the application:
When selecting scale events in the In-Place Editor.
When importing tracks from a project with only channel settings selected.
When using the Chopper plug-in with a high ASIO buffer size.
When MIDI CC values above 127 are used.
When resizing the Key Commands dialog.
When using Send MIDI Clock in Stop Mode.
Reaktionen: dragekonge, Gast92251 und terrablue
https://new.steinberg.net/de/cubase/release-notes/11/
CUBASE 11 RELEASE NOTES
MIDI
MixConsole
Miscellaneous
Stability
Reaktionen: Gast92251 und terrablue
Hmm, habe das Update jetzt über den Steinberg Download Assistant heruntergeladen und der installiert es sofort, das ist natürlich blöd weil ich den Download Assistant auf einer anderen Partition habe als Cubase, das soll auch so bleiben. Ich möchte mein Musikpartition nicht mit gefühlt tausend Assistenten zumüllen.
Alternativ kannst Du das Update auch hier runterladen:
Cubase Pro 11 Downloads | Steinberg
Reaktionen: Gast92251, Dodo_I und terrablue
Danke, werde es in Zukunft von dort aus runterladen.
Reaktionen: Dodo_I
Und hier noch mehr Infos:
MIDI
MixConsole
Miscellaneous
Stability
Reaktionen: Kosaken-Kaffee
Cool, das mit dem verschwindenden Project Cursor hatte ich ständig und nervte gewaltig. Und das mit den Fenster-Fokus-Problemen auch, mal sehen, wie sich das jetzt anfühlt.
Der Rest hat mich jetzt nicht so tangiert.
Na also, so soll das sein. Und ich hatte schon befürchtet, es wäre ein neues Feature ;-)
