Es gibt eine neue Version!
http://www.voxengo.com/product/overtonegeq/
Latest version: 1.2 - Forum: Free Plug-ins
Overtone GEQ is a 7-band harmonic (overtone) graphic equalizer with multi-[g=190]channel[/g] support (supporting up to 8 input/output channels, host setup dependent: if you are using audio host application that conforms to [g=77]VST[/g] specification of version below 2.3, 2 plug-in channels will be available only). Overtone GEQ offers extensive internal [g=190]channel[/g] routing capabilities, and supports mid/side processing.
Beside equalizing, Overtone GEQ applies harmonic enhancement processing. That is why Overtone GEQ is comparably CPU-heavy: it uses 7 harmonic enhancement modules, one for each EQ band. This generates complex harmonic coloration you will probably like a lot.
Since Overtone GEQ implements graphic equalizing by using an array of bell-shaped EQ bands--when you boost/cut adjacent bands--the actual boost or cut may go over the visual setting.
Overtone GEQ conforms to [g=77]VST[/g] specification version 2.4, and so it is able to interface with audio host applications in full 64-bit floating point resolution (if supported by host application).
Features
* 7-band graphic equalizing
* +/- 12 dB [g=105]gain[/g] range per band
* 2 graphic equalizer views
* Multi-[g=190]channel[/g] processing
* Internal [g=190]channel[/g] routing
* [g=190]Channel[/g] grouping
* Mid/side processing
* Complex harmonic coloration
* 64-bit floating point processing
* Preset manager
* Undo/redo history
* A/B comparisons
* Context hint messages
Requirements
* Windows XP or any later 32-bit Windows OS
* 2 GHz processor
* Audio application with [g=77]VST[/g] plug-in support
