J
Joost
Individualist
Moin,
Moe von time.off Audio hat nach längerer Umbauphase seine drei Plugins aktualisiert.
Schwerpunkte waren neben dem Austausch der intern genutzten Audio Engine folgendes:
Die jetzt veröffentlichte Plugin Version ist 1.4.0
timeoff.audio
timeoff.audio
- Lower CPU: every dime plugin uses drastically less CPU, up to 1.6x less on macOS and up to 2.2x less on Windows.
- Much lower latency in dime[tt]: latency drops from 25 ms to about 1.5 ms, so you can now use dime[tt] for realtime recording.
- Oversampling: choose off, 2x, 4x or 8x in the footer controls (dime[mb] goes up to 4x). You can use it to build oversampled effects, and it helps reduce aliasing from nonlinear processing.
A new audio engine, lower CPU, and oversampling | time off audio
Our biggest update since completing the dime line-up: a rebuilt audio engine, big CPU and UI improvements, much lower latency in dime[tt], and oversampling.
Home | time off audio
Explore our critically-acclaimed plugins, and find the perfect tool for your music production needs.
