Ich habe grad mal Meine digitalen comps und deren Beschreibungen durchgelesen - Also es kristalisiert sich herraus , das die analogen Comps die sind , die man braucht . digitale comps sind lediglich versuche , die analogen Geräte zu imitieren .
Fair Compressor
This model of a Fairchild 670 delivers some of the finest colorations in compressor history. Two small trim VRs, BIAS and BALANCE, preset the control side chain action, a 6-step knob determines the timing, and the 2 large INPUT GAIN and THRESHOLD knobs adjust the levels. There are models available for dual, stereo-linked, or mid/side operation.
Leisure Compressor
This model of a popular tube-based optical compressor provides natural and effortlessly musical compression, inspired by the Teletronix LA-2A. Simply adjust the input GAIN and PEAK REDUCTION knob to dial in the amount of desired compression, then adjust the OUTPUT GAIN knob for the desired output level. The COMP setting will give a gentle compression ratio, whereas the LIMIT setting results in a higher ratio.
Ultimo Compressor
The Ultimo Compressor is based on the Urei 1176LN Limiting Amplifier and authentically captures the smooth character of the original class-A output stage in its FET's legendary fast attack.
Start with the INPUT and OUTPUT knobs at the -24 position for unity gain and set the ATTACK and RELEASE knobs fully counterclockwise. Select the compression ratio, then raise the ATTACK knob to lightly compress the signal. Increase the ratio for heavier compression and experiment with ATTACK, RELEASE and INPUT levels to achieve your desired result. Compensate for overall level reduction with the OUTPUT knob.
zu EQ steht da sowas
Xtec EQ1
Inspired by the Pultec EQP-1a, this passive equalizer is a very powerful tool for sound enhancement.
GAIN allows compensation for level changes resulting from frequency adjustments. Toggle the IN switch to engage or disengage the effect. Select the low frequency with the LO FREQ knob, adjust the amount of enhancement with the LO BOOST, then adjust the attack with the LO ATT. The same adjustments are available for the high frequencies.
Xtec EQ5
This Pultec emulation is a classic analog passive equalizer that offers very warm and musical frequency sculpting. Simply select the center frequency for the 3 bands, then adjust how much low and high you want to boost and how much midrange you want to cut.
Google mal nach den simulierten comps als analog Geräte #Preis Ich glaube , die liegen so bei 5000Euro pro Gerät .
Also wie schon vorher erwähnt , die HARDWARE die Teuer ist , ist die Beste . Wieso sonst sollten sie digitale Nachbauten erschaffen , wo doch klar wäre , Ich will sie eigentlich ANALOG, so als Stand-alone-Gerät , was nicht erst hochgefahren werden muß etc und dann , wenn man soweit ist , funktioniert es schon nicht mehr (kaputt) oder die Festplatten crashen oder ein Virus
analog vs digital
analog ist es ein fließender strom, es fließt , wird vielleicht gesplittet , gedoppelt , verschiedene Hürden werden passiert , aber esist ein FLUß, wie ein Bach der fließt und verzweigungen hat , aber denoch EINS ist mit dem ganzen Gewässer oder eine Fotographie die das Licht einfängt und abbildet , es bildet die Realität ab , zumindest im Spectrum dessen , was die Kamera auf Platte festhalten kann
digital = LATENZ , Verzögerung , Berechnung und bei digitalfotos ist es keine REALES BILD ,es ist gefilter , berechnet etc = es ist nicht die WAHRHEIT , sondern eine FÄLSCHUNG, im Übertragenden Sinne . Es ist irgendwas rausgefiltert worden, sodaß Ich einer digitalen Fotographie nichts abgewinnen kann , im Gegensatz zu den Fotos die Ich früher machte mit Meiner 3000Marks Kamera T90 - Es ist so lebendig , während digitale bilder eher Tot wirken
ergo müßte es eigentlich heißen : "ANALOG vs digitale *******"
