u-he Hive and Presswerk updates
Kosaken-Kaffee
Überschätzte Legende
Ja
There are new versions for Hive and Presswerk available: Hive 1.2.1 and Presswerk 1.1.4.
Included are various bugfixes plus an improved Mac installer.
Check the release notes for more info:
Reaktionen: TheSarge und terrablue
Hive 1.2.1 (revision 8296)
Changes:
  • Fixed locale issue which caused scripts to not load on some Linux systems
  • Fixed rare issue causing clicks on note release in left channel
  • Fixed wrong frame count for stereo wavetable samples
  • Fixed wavetable info (disappeared if apostrophe was used)
  • Fixed automatic loading of scripts while being edited
  • Fixed scripting error messages
  • Windows installer now includes “Hive Wavetables.pdf”
  • Improved semitone knob scaling
  • Mac installer improved to prevent permission issues
Known Issues:
  • Windows version not loading wavetables if they contain special characters (Umlauts, ...)
  • Tracktion only - Issue with VST3 and host sync (use VST2 instead)
Presswerk 1.1.4 (revision 8347)
Bug fixes:
  • Fixed latency compensation in Cubase (now works on host start/stop)
  • Fixed latency compensation issue with plugin bypass
  • Fixed latency compensation issue with side chain monitoring
  • Fixed Limiter View punchy mode DPR being wrongly switched off when going back to Main View
