Texture Loom von S1gns Of L1fe (free)
  • Ersteller Ersteller Draf Gracula
Draf Gracula
Gratis oder mit Spende als VST3, AU oder Ableton* Max for live
rpywfzcoqelh3d0egsk2074270i7
Texture Loom
Texture Loom is a free dual-sample atmosphere engine by S1gns Of L1fe, designed for creating evolving pads, drones, cinematic beds, textural layers, and ambient movement from your own audio.
Load two samples, blend between them, shape them with filtering and motion, then send the result into an onboard space/reverb section. Texture Loom is simple enough to start making sound immediately, but flexible enough for slow-burning sound design, generative ambience, and deep sample-based texture work.
Originally built as a Max for Live device, Texture Loom now also includes a native plugin version so it can live outside Ableton* while keeping the same visual identity and workflow.
What It Does
  • Dual-sample playback engine
  • Load your own audio into Sample A and Sample B
  • Start/Stop, Reverse, Start position, Level, Pan, and Rate controls
  • RATE / SEMI mode for continuous speed control or semitone-based pitch movement
  • Equal-power A/B blend control
  • Blend LFO for slow crossfading motion
  • Multimode filter with Lowpass, Highpass, Bandpass, Notch, Peak, and Allpass
  • Filter cutoff, resonance, drive, and LFO modulation depth controls
  • Two Motion LFOs with multiple shapes: Sine, Triangle, Ramp Up, Ramp Down, Random, Drift, and Glider
  • Motion destinations for Blend, Filter, Space, Sample A Start, and Sample B Speed
  • Onboard stereo space/reverb section with Size, Decay, Mix, and Width
  • Master output with metering
  • INIT button for returning to a clean blank state
Good For
  • Ambient pads
  • Evolving drones
  • Cinematic transitions
  • Experimental sample mangling
  • Meditation and yoga music beds
  • Underscore textures
  • Sound design layers
  • Turning field recordings, vocals, synths, guitar, noise, or found sound into atmosphere
Included Formats
  • Max for Live device for Ableton* Live 12 / Max 9
  • macOS AU Instrument
  • macOS VST3 Instrument
  • Windows VST3 Instrument
Important
Texture Loom is an instrument, not an audio effect. Load it on an instrument track or software instrument channel.
A blank instance makes no sound until samples are loaded. If you save a project with samples loaded, Texture Loom will restore those sample paths when the project opens again.
System Requirements
Max for Live version:
Native macOS version:
  • macOS
  • AU or VST3 compatible host
Windows version:
  • Any VST3 compatible host
Free / Name Your Price
Texture Loom is offered as a free sound-design tool from S1gns Of L1fe. Download it, make something beautiful, and visit:
https://www.s1gnsofl1fe.com
Reaktionen: TheSarge
Was heißt denn "Engine"? Läuft das dann als Instrument?
Exakt. Man lädt einfach in den beiden Slots eigene Samples und die laufen dann im Loop.
Also nix mit MIDI Triggern?
Naja, ich guck's mir einfach mal an.
Ne. Eher ein Sample-Manipulationstool. Wie ein Effekt, nur das man halt die Samples direkt in das Plugin lädt.
Aber nicht im Sinne eines spielbaren Instruments.
Naja, ich frage mich halt, wie die dann im Host getriggert werden.
Aber wie gesagt, ich schau's mir am besten selber an.
