v5.975 - April 30 2019
- + API: safer <EXTSTATE encoding of long ascii strings, more efficient encoding of shorter UTF-8 strings
- + ARA: fix potential crash on closing REAPER
- + ARA: fix potential crash when moving media from one ARA track to another [t=219699]
- + ARA: improve loading projects when source files were moved or renamed
- + Actions: fix action to set item start to source media start with negative start offset [p=2118376]
- + Actions: improve Apply FX/Render Item speed when processing large numbers of files
- + Actions: auto-build peaks when pasting if pasted chunk has WANT_PEAKS_BUILD 1 token at top level
- + Audio: prevent race condition where audio device could be left in a closed state when loading a project that changes audio device samplerate [t=219984]
- + Automation items: apply AIs when applying pan/width via VCA
- + Automation items: apply AIs when calculating video processor mute/wet values
- + Automation items: apply AIs when linking track volume/pan to MIDI channels [p=2123953]
- + Automation items: update edge attachment when loading automation item from disk
- + Elastique: update to v3.3.0
- + FX: improve performance while stopped when using large numbers of automated parameters [t=219231]
- + FX: improve live FX multiprocessing scheduling with complex routing
- + FX: optimize automated parameter control surface notifications
- + MIDI: add action to remove duplicate selected events (existing action only removed duplicate notes)
- + MIDI: send MIDI CCs to parent/sends when track has MIDI controls enabled but no media nor FX
- + MIDI: more efficient import of .mid files with many duplicate events [t=219351]
- + Media explorer: import automation item name when inserting via media explorer action
- + Media explorer: support drag-import of multiple automation items at once
- + NINJAM: crosslap .ogg files when concatenating to .wav files from imported clipsort.log
- + NINJAM: improve subsample accounting when importing clipsort.log
- + NINJAM: fix ReaNINJAM writing of stereo .wav files of local streams [p=2124239]
- + NINJAM: improve ReaNINJAM sound quality at end of each interval
- + Notation: duplicate articulations when duplicating notes up/down an octave [t=220147]
- + Notation: fix musicxml export issues with multiple voices
- + Notation: improve display of tied voiced notes
- + Notation: improve proportional spacing display [t=219655]
- + Notation: split long beams more predictably [p=2125451]
- + OSC: fix incorrect saving of action bindings for non-main sections
- + Project bay: add support for automation items
- + Project bay: optimize copy/move of large numbers of files
- + Project help: report correct time since last manual project save [t=219875]
- + Project save: optimize copying of project media files [t=216526]
- + Projects: losslessly encode long/complex track/take/marker/region names in project/undo state [p=2120673]
- + ReaScript: add GetSetAutomationItemInfo(D_POOL_QNLEN), MIDIEditor_SetSetting_Int()
- + ReaScript: add GetSetProjectInfo_String(RENDER_FORMAT), GetItemFromPoint(), GetTrackFromPoint()
- + ReaScript: add P_EXT: prefix for extension-specific string state for GetSetMediaTrackInfo_String(), GetSetAutomationItemInfo_String(), etc
- + ReaScript: add GetSetTrackSendInfo_String() and GetSetEnvelopeInfo_String() (for P_EXT: use)
- + ReaScript: allow using various GetSet..Value() functions with strings, automatically converting numbers to/from string
- + ReaScript: update to Lua 5.3.5
- + Render: allow dither and noise shaping when rendering stems
- + Render: fix potentially incorrect region time wildcards [t=213312]
- + Ruler: display selected regions (for rendering) more distinctly
- + Ruler: add context menu item to render individual regions
- + Snap: add option to snap time selection to media item edges [t=218957]
- + Take FX: add actions to set take FX on/offline [t=220052]
- + Take FX: update FX window titles when duplicating take via action
- + Take FX: flush all take FX on playback start
- + Theming: add new HSV blend mode with bugfixes, old behavior is now deprecated HSV adjust blend mode
- + UI: improve mute/solo swipe behavior when there are hidden grouped tracks [t=219783]
- + UI: improve multimonitor tooltip behavior
- + UI: improve take envelope button drag/click behaviors
- + VST: automatically default to VST3 soft reset for plug-ins that appear to support setProcessing
- + VST: prevent hard reset from called from audio thread when flushing buffers
- + linux: improve keyboard handling with modal window open
- + linux: install SIGPIPE handler
- + macOS: prevent network related SIGPIPE crashes
