REAPER v2.5 - 20. oder 21. Sep. 08
  • Ersteller Ersteller Cablebob
reaper2012-install.exe
v2.012 - November 23 2007
+ moved project pitch shift settings to audio settings tab
+ project time offset setting, project measure offset setting
+ [g=32]midi[/g] clock+spp output now uses quarter notes rather than beats (for better timesignature compatibility)
+ [g=32]midi[/g] CCs assigned to actions will now prioritize any active [g=32]midi[/g] editor over the main action
+ fixed some behaviors of "move edit cursor to start of loop selection" option
+ rewire: faster init of rewire apps (less gui flicker too)
+ take imploding: fixed possible use-after-free bug when imploding [g=32]MIDI[/g] items (T,MP!)
+ better updating of fx list titles when resizing (T,MP!)
+ cleaned up some fx list [g=46]bypass[/g]/offline controls (T,MP!)
+ mpeg decoder: better frame synchronization for invalid bitstreams
+ ReaFIR: improved undo state saving (T,MP!)
+ Internal audio sink configuration and reamote cleanups to endianness for [g=18]mac[/g]/ppc compatibility
+ Added new dummy audio device in preferences so you can run purely [g=32]MIDI[/g] or purely network instances of REAPER
+ [g=77]VST[/g]: better 64 bit setting for v2.4 VSTs
+ [g=77]VST[/g]: plug-in configurations are now always stored in little endian (regardless of the native endianness)
+ [g=77]VST[/g]: can now find plug-ins using different extensions (i.e. if the project specifies file.[g=77]vst[/g], file.dll is used on windows)
+ ReaTune: updated to support new project time offsets
+ Spectro: updated to support new project time offsets
+ update: fixed excessive [g=32]midi[/g] device cache invalidating
@Kainer
So macht man das :P
ich werde mich bessern und angepasster arbeiten ;)
Oh, die Abstände zwischen den Updates werden grösser...
Vielleicht kann man demnächst auf ein Update hoffen, das ein paar Tage später kein *alter Hut* mehr ist ;)
Ich glaube das liegt daran, dass Justin wohl gerade viel an der [g=18]Mac[/g]-Version schraubt. Zumindest wenn ich die Foren-Einträge richtig deute...
auf die [g=18]mac[/g] - version warte ich schon sehnsüchtigst - hoffe du hast recht.
reaper2013-install.exe
v2.013 - November 27ish 2007
+ preliminary basic MMC response
+ reatune: more efficent update mechanism (T,MP!)
+ master track automation mode reset on new project
+ options to prevent media buffering and anticipative FX per track
+ uad synchronous mode now can work with anticipative FX enabled, but be sure to set any tracks with UAD
(or tracks they are routed to) to prevent anticipative FX
+ new action: "Set selected item end to cursor"
+ new action: "Set selected items length to source media length"
REAPER v2.014 - November 28 2007
Download: 3.1 MB installer
* [g=32]midi[/g] editor: fixed bug where editing notes in hidden channels was sometimes possible
* files with unknown extensions are attempted (as last resort) to be opened with wav/aiff reader
* action list selects first item by default (for easier running)
* fixed crash in vis preferences dialog when Winamp 5.5+ is installed
* doubleclick now edits markers/time sig markers, alt click removes
* doubleclick now edits regions, shift+doubleclick selects them, alt+click removes them
* actions: edit/delete marker/region/tsmarker near cursor
http://reaper.fm/files/2.x/reaper2014-install.exe
REAPER v2.015 - December 4 2007
http://www.reaper.fm/files/2.x/reaper2015-install.exe
single clicking the middle area of regions no longer seeks
changed region clicking to be shift+doubleclick for edit
[g=32]midi[/g] editor: better singleclick add/delete (only deletes on non-control parts of notes clicked)
reaxcomp: GR text display with 500ms [g=357]peak[/g] hold
reaeq: better graph accuracy (thanks loser, rbj)
reaeq: option to show [g=43]filter[/g] phase response
reapitch/readelay: "add tap/shifter" copies current tap/shifter settings
readelay now defaults to a musical delay length
save fx chain, copy/cut fx now copy [g=32]midi[/g] learn bindings as well
internal scrollbar updates ([g=18]mac[/g] porting)
JS: removed real-FFT support (it was somewhat broken anyway), smaller FFT implementation
REAPER v2.016 - December 7 2007
Download: http://www.reaper.fm/files/2.x/reaper2016-install.exe
fixed "[g=84]insert[/g] time signature measure from loop selection" for non /4 signatures
fx chain: fixed a possible crash bug when undoing edits
fx chain: fixed short labels when moving items
js: JS effects can now render their own UIs using code - http://reaper.fm/jsgfx.php for more info
js: added $xdeadbeef hex support, $'x' for ASCII codes
js: slider names beginning with - will not be shown in the UI (but still automatable)
js: each effect now has 8 million memory entries (up from 1 million)
js: max FFT size upgraded to 32768 (from 4096)
reaeq: improved phase display (no wrapping)
reaeq: new default band mode, deprecated old mode for compatibility
reaxcomp: fixed generic ui display
reacomp: attack and rms sizes now show an extra digit of precision
themeing: added tcp_mainbg[sel], [m,t]cp_folderbg[sel] images
sstillwell/1175: added GR meter
added gfxanalyzer and gfxscope as basic examples of JS GFX
added fft_noise_generator as a diagnostic tool (useful with gfxanalyzer)
es geht vorwärts
REAPER Latest Version
REAPER v2.017 - December 11 2007
Download: http://reaper.fm/files/2.x/reaper2017-install.exe
holding ctrl when importing [g=32]MIDI[/g] files will force prompting to use any tempo information (normally files with minimal tempo information wont bug you with this)
fixed bug where enabling write automation would reset volume to -inf
tweaked IIR based resampling filters (for fast+IIR mode)
faster, more effective extreme resampling mode, faster best mode (for sweep tests, [g=357]peak[/g] noise on these is around -140dB and -120dB respectively)
ReaStream: copying to reastream.dll reastream_xxx.dll allows you to set max number of channels supported (2-64)
js: @serialize support so JS plugins can save arbitrary data in the project (todo: support sending serialized data via reamote, in presets)
js: memory/variables arent cleared for effects with @serialize section
js: removed text mode chain ui for some significant size savings
js: added extraordinarily fun new effect, sequencer_baby
improved js gfxanalyzer, added gfxspectrogram, added sine_sweep (useful for testing)
updated some schwa and loser js plugs
Oh, schon wieder Updates :D
Ich sehe gerade das ich irgendwann bei 2.13 aufgehört habe Updates zu installieren. ist ja jetzt schon 2.017 :-o
ich glaube Justin und Co schlafen und essen NIE! ;)
deprimierend wie die ihre updates raushauen
wenn man mit anderen seq arbeitet
echt wahr, ich bin mittlerweile ganz umgestiegen, obwohl ich sogar noch logic 8 gekauft habe. wobei das nicht schlimm war, da es sich allein für die jampacks gelohnt hat.
aber arbeiten: nur noch mit reaper.
gibt nix was ich vermisse.
und ich LIEBE den mixer. (mal abgesehen von dem besten support den ich je erleben durfte.)
ich kann einfach nicht mein cubase know how wegwerfen und von neu beginnen!
das pack ich nicht mehr!
und wenn ich jetzt wechseln würde dann nur in richtung pro tools!
aber auch das kommt nichtin frage
lifes a bitch
hab ich auch gedacht, war aber halb so schlimm.
durch arbeiten mit cubase/logic/flstudio hat man ja n einblick und dank netter internetforen und guten manuals sowie tutorials ist das nur noch ne sache von tagen, je nachdem wieviel zeit man sich nimmt.
ich kanns jedem nur WÄRMSTENS empfehlen.
lifes a bitch... buy it, use it!
wieso schmeisst du denn dein (cubase) knowhow weg? du machst doch da nix anderes, als in cubase auch oder protools oder jeder anderen [g=17]daw[/g].
da sind n paar arbeitsschritte anders die einer kleinen einarbeitungszeit bedürfen und man muss nich dauernd zwischen tools umschalten und das defaultskin gefällt am anfang vllt. nicht, aber wenn man einen kanal kennt, kennt man alle...
skin lässt sich anpassen, tastatur frei belegen, makros speichern, fx chains speichern und rumschubsen nach belieben, routen nach belieben, ne menge feine mitgelieferte fx, bugs werden nach melden im forum oder chat bei cockos idr mit dem nächsten update gefixt, richtig gute feature-requests werden auch umgesetzt und können idr in einer der nächsten updates erwartet werden......im grunde is für jeden n grund dabei, reaper mal auszuprobieren....:D
gruß,
micha
Reaper-2.18.exe
v2.018 - December 14 2007
+ ReaMote: updated protocol to properly support play state for plug-ins
+ Added presets for reacomp, readelay, reagate, reaeq, reaverb and reaverbate
+ Added preset-autoimport support
+ ReaRoute: optional support for 32 bit floating point samples
+ [g=12]ASIO[/g]: floating point output is no longer clipped
+ JS: gfx_blit, gfx_blur, gfx_blitex, png loading support
+ JS: spl(x) alternative (programatic) syntax for spl0, ...spl63
+ JS: fixed PDC on first play issues
+ JS: @serialize state support for reamote, preset saving, etc
REAPER v2.019 - December 17 2007
Download: http://www.reaper.fm/files/2.x/reaper2019-install.exe
[g=77]VST[/g]: fancier scrollbars, fixed some positioning bugs when resizing and scrolled (T,MP!)
fixed wrong checkbox setting when arming nonexistent envelopes (T,MP!)
fixed some small routing/envelope scrollbar issues (T,MP!)
fixed [g=32]midi[/g] editor CC lane resize bug (FO,MP!)
JS: updated IX [g=32]midi[/g] tool II, added smpte_ltc_reader
better default for new bands in ReaEQ
added grizlees great reaxcomp presets
den einen bug habe ich gestern im forum gemeldet, abends gabs dann noch den fix. knaller!
REAPER v2.020 - December 21 2007
Download: http://reaper.fm/files/2.x/reaper2020-install.exe
* initial contextual help in Preferences screens
* [g=32]midi[/g] recording: better automatic delay compensation
* preliminary slave spp/clock and mtc/ltc timecode. needs testing.
* preliminary [g=12]ASIO[/g] Positioning Protocol slave synchronization (needs testing as well)
* record button on transport now can reflect record punch mode (transport_record_loop.png, transport_record_item.png)
* play button on transport now can reflect slave sync state (transport_play_sync.png, transport_play_sync_on.png)
* right click on play button now shows slave sync configuration, (alt+right click to toggle sync enabled)
* right click on record button now shows record mode options
* actions to open timecode sync panel and toggle sync
* transport context menu now has slave sync/record mode options
* better transport status display (goes multiline, shows slave/bouncing status)
* improved smpte_ltc_decoder synchronization with varying frame/samplerates
* fixed snap to grid at any distance with grid snapping disabled behaving funny
* fixed CPU munch/weird sounds at ends of pitch shifted items with loop source disabled
* fixed crash in Performance [g=226]Monitor[/g] on some machines
* better audio input/output name aliasing (handles duplicate named inputs better, changing indices)
* ReaFIR: fixed Reamote support
* updated (smaller) Spectro build
Hat sich mal wieder einiges getan :)
