MIDI editor
Download
- 14-bit CC editing fixes
- allow screensets to save/load editability of individual media items
- allow scroll-left actions to scroll past item start but not project start
- avoid double-drawing many updates
- change default editor selection link options, may change options in existing installations
- do not include end-of-item all-notes-off in list of channels that contain data
- faster updating when using hand scrolling
- fix 14-bit CC editing in event properties
- fix drawing issues at extreme Zoom/time combinations
- fix various issues with show only used/named notes
- fix maximize state incorrectly being reset
- fix next/previous note navigation/selection issues
- fix pasting to secondary editable items that are looped
- fix pasting to secondary items that start before active item
- fix restore of macOS menu after renaming note
- fix secondary editor zoom inconsistency with different PPQN settings
- fix zoom-selection with secondary items at earlier time
- improve behavior with multiple pooled items as secondary editable items
- improve copy/paste behavior with multiple contexts editable on multiple tracks
- improve start position accuracy when quickly painting new notes
- improve undo messages on various lane edits
- improve behavior when opening multiple items at once
- improve behavior with hidden parent tracks
- when loading note names from recent list, merge with current note names when holding shift key (feature lost in v5.0)
- properly enable menu option for cut/copy with CCs/Text/SysEx selected
- fix adjacent note deleted on paste bug
- prevent event sorting from sometimes destroying notes
- fix potential deadlock issues with crop/delete active take and MIDI editor open
- add edit modes to move selected inputs directly towards or away from a specific speaker
- add per-input channel controls to reverse (mirror) edits
- add relative speaker influence mode
- change default 9.1 channel order to match SMPTE (existing projects are not affected)
- hold down control key to override reverse/mirror edits when moving inputs with the mouse
- hold shift key for faster edit, control key for slower edit
- in relative mode, prevent bleed into speakers at opposite edges of the space
- initialize arrangements with speakers closer to the edge of the space
- restrict edits to the visible space
- allow pasting of points into existing items
- avoid setting point shape to square when FX is offlined
- improve behavior when copy/pasting overlapping media items
- create a new automation item when pasting points in AI-only mode
- fix arrange view updating when removing bands that have automated parameters
- fix automated band behavior for first block after stop
- fix undo when removing bands that have envelopes
- support NamedConfigParm BANDTYPEx and BANDENABLEDx
- coalesce send volume/pan automation additions via action
- defer undo point for single-click media item selection
- flush any latent undo states before project save
- improve cursor position undo point behavior
- notify MIDI editor/Project Bay from various item selection change actions when item selection undo is disabled
- add compatibility setting to flush VST3 buffers with hard vs soft reset
- fix state saving for bypassed/take FabFilter VST3
- when forcing VST3 bus channel count, immediately reinitialize plug-in I/O
- improve compatibility by resetting/re-initializing plugins only from main thread
- prevent hanging notes when resetting plugins on loop
- improve performance with folder tracks that have PDC
- process receives similar to folders
- remove old logic for reducing worker threads when not using anticipative FX processing
- make automatic worker scheduling mode slightly more aggressive
- reduce underruns when repositioning the edit cursor soon after stop
- fix snap behaviors when inserting new point via shift+click
- transform MIDI take envelopes when modifying time map
- fix selection behavior for various "Item edit: item under mouse cursor" actions
- fix corner case where audio is muted when the gate should open [p=kenny]
- clear old point selection when duplicating points via mouse modifier
- do not round glued MIDI to audio samples
- fix incorrect clip indicators with +0dB maximum range
- auto-add of time-selection length MIDI items obeys new MIDI item looping preference
- set doctype correctly on timewise export (which is not supported by many programs)
- fix paste with more than 32 empty tracks between items (existed since 2005)
- improve position calculation logic
- fix render preset dither when loading all settings
- allow mapping double-click to no action
- improve snap/grid consistency with snap/grid settings linked
- fix storage/application of very low compression thresholds
- re-open peaks when re-enabling audio for video item
- pass through most shift-modified keys to main window
- TrackFX_AddByName/TrackFX_GetByName/etc can take VST2:/VST3:/VST:/AU:/JS:/DX: prefixes
- add ReorderSelectedTracks()
- SetEnvelopePointEx() will propagate envelope item changes when not modifying point time and nosort=false
- SetTrackSelected() notifies various windows of state change
- Undo_EndBlock() with empty string uses first item in block if available
Download
