Reaper 5.60
Automation items
  • add option to disable envelope outside of automation items (automation-item-only mode)
  • support preview in media explorer
  • support various context menu actions from media explorer
  • fix potential hang when populating submenus
  • add automation item double-click mouse modifier to load saved automation item
Peaks
  • add display settings option to rectify peaks/waveforms
  • add display settings option square-root-scale peaks
Spectral editing
  • clear spectral edit selection on item click
  • separate controls for fade in/out/low/high rather than just time/frequency
  • shift+drag of edge adjusts fade of that edge
Envelopes
  • add option to always create new automation item when writing automation (always enabled in automation-item-only mode)
  • change bezier curve smoothness calculation so that curves are less sensitive to changes in surrounding points (existing projects are unaffected)
  • add theme color for unselected automation item
  • fix activating receive envelopes from envelope dialog
  • fix end point behavior of action to insert four points at time selection
  • generally restrict mute envelope points to on or off state
  • respect "ignore mousewheel on track panel faders" for envelope control panels
  • show move guides for automation item edits
  • in automation-item-only mode, chase previous automation item value on seek
Solo
  • improve hardware send behavior when soloed track sending to another soloed track
  • improve solo-in-place behavior for receives on folder tracks
  • improve solo-in-place behavior when both sides of a send are soloed
  • add option for unsoloed master/parent send when a soloed-in-place track sends to another soloed track
FX
  • fix ID collision in quick-add FX/FX chains menu
  • allow VST plug-ins to override escape key, spacebar via effEditKeyDown
MIDI editor
  • add actions to navigate by channel, voice, staff
  • obey mouse modifier setting to select/deselect other notes when inserting note on single click
Pitch shifter/timestretch
  • add new menu system for parameter modes
  • add Rubber Band Library
  • support loading extrashifter.dll/.dylib for developers
ReaScript
  • improve behavior of fade shape setting via SetMediaItemInfo_Value() with C_FADEINSHAPE, etc
  • add GetUnderrunTime() API
Take FX
  • improve handling of PDC changes
  • improve handling of PDC with master playspeed envelopes
Undo
  • prevent storing many duplicate empty state blocks in history
  • support more efficient encoding of track configurations in history (new undo histories will not be loadable by 5.50 or earlier)
Mouse modifiers
  • fix actions to set default mouse modifiers for newly-added contexts
Preferences
  • move various solo/mute options to Audio, Mute/Solo tab
ReaEQ
  • optimize parameter updates
Tooltips
  • show correct tooltip when track muted due to envelope
Windows
  • improve support for application/user paths with non-latin characters
