REAPER 5.28
MIDI editor
- fix actions to set event channel with multiple editable MIDI items
- add actions to quantize note positions to specific divisions
- add actions to select CC events under selected notes
- add actions to select next note with lower or higher pitch
- consistently display and mouse-select selected/unselected notes in multiple channels
- display CC events for active channel in front of other event
- do not extend item length on paste when configured not to auto-extend
- do not select note when clicking on velocity bar with edit or ramp mouse modifier engaged
- edit only active channel CC events when mouse modifier set to edit+draw
- ensure that 1-pixel-wide notes are visible regardless of coloring preferences
- fix incorrect display of 14-bit bank select messages in list view
- preserve overlapping notes after closing/reopening editor when option is enabled
- respect channel dropdown (including "all channels") when editing or marquee selecting CC events
- respect option to select CC with notes during all mouse selection actions
- restore keyboard focus to docked editor after clicking MIDI toolbar button
- return focus to editor after closing grid/note length dropdown
- support editing notes that start or end beyond the edge of a trimmed media item
FX
- copy/move all track FX via drag and drop of track/mixer FX button
- avoid auto-resizing chain window too small
- fix parameter modulation with inverted range parameters
- improve VST/AU generic UI auto-resize behavior
- improve parameter learn soft takeover behavior
- reduce CPU use of MIDI learn assignments
Notation editor
- improve lyric editing
- preserve notation data when editing note channel
- support mouse click modifiers that are actions from the action list
- target the active item when displaying multiple overlapping items on the same track
- when displaying a single track on multiple rows, show time signature only when it changes
- when exporting a single track to PDF, print both the project name and track name
Actions
- fix soft takeover reset action
- improve soft takeover behavior for various actions
- automatically convert various key bindings between Windows and macOS encodings
- add actions to toggle or set MIDI input quantize amount for all tracks, selected tracks, or last touched track
Automation
- update volume/pan/width fader positions when hiding/disarming envelopes in touch mode
- optimized envelope undo state handling
- avoid crash when copying/moving take envelope to empty media item
- drag+drop take envelope targets take lane under mouse cursor rather than active take
- support drag+drop of take envelope button to items on same track
macOS
- show file type option in all save-as/export windows when multiple types are available
- avoid changing toolbar focus on click
- preserve top position of FX chains when switching FX
- restore action window position properly when reopening
Virtual MIDI keyboard
- toggle (not just set) option when running action to send all input to keyboard
- allow text field input even when using send all input to keyboard
- pass through unbound keys when using send all input to keyboard and VKB lacks focus
JSFX/ReaScript EEL
- add mem_get_values(offset,...) and mem_set_values(offset,...)
Media item properties
- improve layout, scrollbar behavior, and support for large fonts
MIDI
- fix intermittent missing notes when pasting MIDI directly into the arrange view
MusicXML import
- import enharmonics correctly
Project
- do not load template project after failing to load requested project
Super8
- fix bug when starting playback of channel that has note yet been recorded
Tempo map
- adjust beat-based (MIDI) media items correctly when editing around a time signature marker that creates a partial measure
Track manager
- update layout colors when changing track colors
Undo
- updated RPP-UNDO format, earlier REAPER versions may warn, not use track envelope state from new undo histories
API
- allow more precision in CSurf_OnVolumeChange
- update layouts when setting track color
Download
