REAPER 5.25
FX
- add option to ignore FX chain keyboard shortcuts and send keys to main window
- increase channel count as needed on copy/paste of FX, FX chains
- increase channel count as needed on drag and drop FX to item take FX
- improve bypass checkbox positioning
- store comments in FX chains, copy/paste
Timestretch
- fix potential glitch on source loop
- improve media explorer timestretch behavior with looped preview
VST
- fix udetection of used channels
- improve behavior when initializing resizeable VST3 UIs
MIDI
- improve behavior when stopping overdub/replace recording with held notes
- fix overdub/replace recording to MIDI items that ignore project tempo
- restore 5.1x behavior of preserving overlapping notes that have different selection/mute states
- add option to export project markers as either MIDI cue or MIDI marker event type
- support export of tempo/time signature information to type 0 MIDI files
- on multitrack import, do not import events from the header track into the first imported media item
- allow resizing pooled MIDI via API using PCM_SOURCE_EXT_SETSIZE by using flags
- fix copy/paste of notes with large PPQN values
- fix incorrect parsing of multiple note-ons in a row
MIDI editor
- draw events at their precise integer MIDI tick location in piano roll view
- fix CC display with multiple overlapping channels
- prevent drawing zero-length MIDI notes
- fix resizing CC lanes when many lanes are displayed
- fix duplicate messages when editing bank/program event channel
- fix marquee selection drawing when many CC lanes are displayed
- improve move cursor left/right actions for items which do not start on grid
- properly round event position when editing via list view or event properties dialog
- restore track list, notation, and other displayed data when bringing file-based MIDI online after switching focus away
Notation editor
- add actions to explicitly minimize or un-minimize ties for selected notes
- add preference to minimize ties for all notes by default
- automatically position digits for beamed tuplets, improve bracket positioning for non-beamed tuplets
- change voice for selected notes if appropriate when creating/modifying tuplets
JSFX
- add fft_real/ifft_real (thanks Tale)
- fix used-channel detection for MIDI-only processors
- update many stock plug-ins to define their I/O
Actions
- support importing/exporting OSC bindings to ReaperKeyMap files
Automation
- improve point paste edge case behavior
Control surfaces
- fix potential MCU crash when managing selection state
Dynamic split
- improve handling of existing stretch markers
Media import
- if imported media contains title information, use this to name the track rather than "title - filename"
Performance meter
- fix some display arrangement issues when changing view options
ReaSurround
- allow adjusting speaker parameters en masse using ctrl+alt+slider
Render
- clear transport button state when rendering
Take lanes
- add option for clicking take lane changes active take for multiple selected items
Tracks
- improve reordering of tracks when dragging tracks upwards in place
Transient guides
- avoid adding duplicate stretch markers to self, grouped items
Undo
- do not add undo point when dragging does not result in reordering tracks
Wave
- support reading incomplete .wav files with 0-length data chunk
Windows
- improve behavior of single track send, media item properties windows with large fonts/scrollbars
Download
wirklich seltsam
Ich hab immer dieses Bug, dass wenn ich Automatisation auf Latch stelle und starte, verschiebt sich hinterher der Urzustand. Bei einem Gain ist dann der Default bei 0.3 dB statt 0 dB, und ich muss das korrigieren. Das ist mal ein richtiges Bug, nicht dieser Pipifax da oben.
Komisch, dass die richtigen Bugs niemals auffallen. Also die, die das taegliche Arbeiten behindern. Ich bin wohl der einzige User, alle anderen User sind ein Hoax.
wirklich seltsam
Bug report gemacht ?
http://forum.cockos.com/forumdisplay.php?f=22
ja. jetzt.
Den Elephanten im Raum erwähnt, den niemand sehen wollte. ;D
Ok, konnte ich reproduzieren, aber auch nicht immer komischerweise, hmmm...
Ist das bei dir immer ?
Immer weiss ich nicht, aber oft genug, um mich zu nerven, eigentlich fast immer, wenn ich so drueber nachdenke.
Uebrigens hab ich jetzt auch ein schwerwiegendes Midiproblem, und zwar unter PC: dort gibts ne hoerbare Latenz, wenn man externe Synths anspielt. Ganz merkwuerdiges Ding. Muss ich demnaechst nochmal testen. Bei Cubase tritt das Problem nicht auf, gleiche Hardware und gleiche Treiber.
Und das Aergste, koennte an Plugins liegen: ich hab zwei Projekte, wo im Offline Rendering hin und wieder ein Click sich einschleicht. Das ist schon fatal. Da muss man extrem auf der Hut sein :)
