REAPER 4.5 ist da
  • Ersteller suboptional
suboptional
Gesperrter User
Auf's Reinkopieren des umfangreichen changelogs verzichte ich mal...
Ok, dann mach ich es. ;)
v4.5 - August 28 2013
+ API: GetSetMediaTrackInfo with I_RECARM no longer generates undo points
+ API: added GetTrackDepth function
+ API: added functions to get media item track, parent tracks
+ API: fixed DoActionShortcutDialog() not updating configuration files
+ API: undo/redo cancels any pending undo blocks
+ Actions: added set item name from active take filename
+ Actions: fixed label for scroll view horizontally by page [issueid=4805]
+ Autosave: configurable option for when to autosave (always, stopped, or not-recording)
+ Click source: better behavior when using pitch shifting/timestretch
+ Click source: do not adjust click source rates when adjusting tempo
+ Directory cleanup: better media path resolving for freeze and project bay referenced files
+ Dockers: improved autotransparency behavior
+ Envelopes: better behavior with multiple points selected
+ Envelopes: added actions to select various track envelopes
+ FX: Monitoring FX support - useful for analysis, room adjustment, or other non-project related processing
+ FX: fixed changing parameters via program change causing potential hang [t=127004]
+ FX: safer UI updating when changing bypass/parameters via automation
+ FX: dropping FX on a track input fx, record arm, record mode, or record input will put FX on input chain
+ FX: input FX are now properly tracked by undo system
+ Fades: splitting items with crossfade set will set both crossfade and default item fades [p=1168997]
+ Grid: better support for measure lengths that are not multiples of grid size [t=115128]
+ Grid: framerate grid/snap support
+ JS: $xHEXCONSTANT now parsed same as 0xHEXCONSTANT, no conversion to 32 bit signed integer
+ JS: editor has improved non-english keyboard support, syntax highlighting, better resizing support
+ JS: _global.variable support, regXX alias to _global.regXX
+ JS: added atomic_setifequal(), atomic_exch(), atomic_add(), atomic_set() and atomic_get()
+ JS: improved behavior with fx that define input or output pins but not both
+ JS: invsqrt() now produces same results for negative inputs on x86-64 and x86/PPC
+ MIDI editor: support for editing multiple MIDI items at the same time
+ MIDI editor: added track list and media item lane, filter window now filters only MIDI events, not media items
+ MIDI editor: track list and media item lane control which media item is active, which others are visible
+ MIDI editor: optionally preview all selected notes that start at the same time position
+ MIDI editor: optionally preview notes when editing or changing selection via keyboard action
+ MIDI editor: actions to activate next/previous item, visible item, or track, action to enable/disable relative snap
+ MIDI editor: added mouse modifiers to move/copy selected notes by dragging in the piano roll (no need to click the note again)
+ MIDI editor: added toolbar snap button context menu
+ MIDI editor: many bugfixes and performance improvements
+ MIDI editor: improved action to view raw MIDI data
+ MIDI editor: new cursors midi_noteedge_l, midi_noteedge_r, midi_stretch_l, midi_stretch_r
+ MIDI editor: save and load bank/program select files with tracks, rather than with individual MIDI takes
+ MIDI editor: stretch CC events when stretching a group of notes (when option enabled)
+ MIDI editor: support for 14-bit CC messages in piano roll and event list
+ MIDI editor: theme colors for out-of-bounds piano roll
+ MIDI editor: theme image for midi_item_bounds.png, table_remove_off, table_remove_on
+ MIDI editor: track list shift+click expands/collapses folders or track items
+ MIDI editor: track list has right-click menu option to choose which tracks to show/hide in track list
+ MIDI: fixed chasing notes in certain instances [issueid=3639]
+ MIDI: fixed multiproject hang bug [t=123903]
+ MIDI: import SMF cues that are embedded in the tempo track
+ MIDI: optionally embed project markers as MIDI cues when exporting project MIDI
+ MIDI: optionally import embedded cues as project markers
+ MIDI: when playing back looped, improved sample-level rounding to avoid duplicate midi notes
+ MTC: fixed hour-rounding issue with 25fps
+ Marker/region manager: import/export csv properly supports commas/quotes (RFC 4180) [issueid=4798]
+ Metronome: Preferences/Audio setting to choose default output
+ OSX: PowerPC build has improved defaults for better performance
+ OSX: fixed fx pin connector text
+ OSX: localized audio device info menu support
+ Pan: enabled overriding pan mode for the master track [issueid=4852] [issueid=3452]
+ Performance meter: options to show/hide empty tracks/master track/Monitoring FX
+ Project bay: better undo integration for speed/RAM use, faster undo state loading
+ Project bay: improved sorting for length, track, position with fallbacks [issueid=4825]
+ Project tabs: option to put project tabs on left edge of window rather than top
+ ReaPlugs: ReaControlMIDI supports channel pressure messages
+ ReaPlugs: improved use/calculation of constants throughout that might affect some win64/AMD systems
+ ReaPlugs: fixed potential for crash in ReaFIR analysis code on incorrectly-sized windows
+ ReaPlugs: safer ReaInsert audio device hooking
+ Recording: MIDI input mode with pdc-adjust respects loop end timing
+ Recording: preserve PDC monitoring properly observes i/o latency for audio
+ Routing: reduced excessive volume/pan messages being sent via MIDI sends when stopped/looping
+ Stretch markers: action to remove stretch marker at current position
+ Stretch markers: actions to navigate to next/previous/nearest stretch marker
+ Stretch markers: guide indicators when moving
+ Text rendering: fixed potential memory overflow bug, thanks JeffOS
+ Time signatures: improved beat-attached behavior when removing points [issueid=4788]
+ Time signatures: fixed adding editing markers at zero/negative measure counts
+ Time signatures: improved adjusting media items when changing time signature denominator (related to change in 4.32)
+ Time signatures: improved behavior moving/copying regions with time signature markers [p=1229213]
+ Timestretch: fixed issues in 4.4x with playspeed envelopes and preserve pitch
+ Timestretch: latest AVX-enabled Windows builds of Elastique
+ Timestretch: fixed Elastique issue on some win64/AMD systems
+ Timestretch: allow non-1.0 playrates that are very close to 1.0 [issueid=4787]
+ Track manager: fixed extra spaces being added when renaming child tracks
+ Undo: extensive optimizations and improvements
+ Undo: avoid excessive state loading when undoing changes to track order/counts
+ Undo: better reuse of undo buffers when changing track order/counts
+ Undo: improved memory use, scan for common blocks in history when adding states
+ Undo: incrementally updated RPP-UNDO files, can make for much faster save of undo history
+ VST: improved bridged embedded support for SE plug-ins (broken in 4.40)
+ VST: when mode set to not scan VST info, apply renames after updating plugins
+ Video: fixed file closing hang when using WMA files on Windows
+ WavPack: fixed crash on reading invalid wrapper chunks
+ Windows: added WMA as supported file extension
+ Windows: fixed CPU usage display working intermittently on systems with large uptimes
+ Windows: installer better handles incorrect ReWire installation states
+ Windows: topmost button activation tweaks (fixes for embedded bridged plugins and native plugins such as Kontakt)
Super, unter anderem jede Menge MIDI Editor Verbesserungen dabei!
+ Stretch markers....
coool!
F**K YEAH!
Es gab zwischenzeitig zwei neue Updates:
v4.52 - September 5 2013
+ Actions: various actions better respect edit cursor in undo state
+ Graphics performance: fixed high CPU use when displaying media items with many embedded cues
+ MIDI editor: better cursor positioning on note edge clicks [p=1233863]
+ MIDI editor: fixed scroll issues, improved play cursor behavior
+ MIDI editor: track and channel selection available in both piano roll and event list view
+ MIDI editor: fixed channel filter initializing incorrectly when loading projects
+ MIDI: fixed pasting events into blank area of arrange view
+ Metering: fixed track metering inaccuracies on looped playback
+ Playback: fixed rare but possible increased memory use when changing loop selection during playback
+ ReaPlugs: improved undo point notification for various controls
+ Routing matrix: fixed scroll issue [p=1233512]
+ Video: fixed audio decoding issue when using VLC decoder on files containing a 32bps audio stream
v4.51 - August 30 2013
+ MIDI editor: dropdown box above keyboard area to select active track
+ MIDI editor: better performance updating edits with lots of pooled items
+ MIDI editor: improved source length editing behavior
+ MIDI: faster creation of pooled midi items
+ MIDI: fixed stuck note on looped playback introduced in 4.5
+ Undo: reduced excess work/flicker when in an undo block
<div>
</div>
<div>
</div>
<div id="_mcePaste" style="positistyle="positipositipositipositipositistyle="positistyle="positipositiposition: absolute; left: -10000px; top: 0px; width: 1px; height: 1px; overflow: hidden;"> + Undo: reduced excess work/flicker when in an undo block</div>
