REAPER 4.30 ist draussen!
  • Ersteller Ersteller user01
U
user01
•License: REAPER evaluation period is now 60 days
•Crossfade editor:
?activates for selected items that are adjacent or overlapping
?crossfades can be constrained to be equal gain or equal power
?default mouse modifier, double-click on crossfade to open/close editor
?new dialog for editing various parameters of crossfades
?themeable colors for active fades
•Fades/crossfades:
?new S-curve fade shape
?changing crossfade shape via right-click menu affects all selected crossfades
?default crossfade shape is equal power (existing projects are unchanged)
?fade curvature can be edited via mouse modifier, media item properties, or crossfade editor
?new cursors for fade/crossfade curvature, crossfade width adjustment
•Mouse modifiers:
?added behavior to move item contents and ripple adjacent items
?new action to adjust length of two fades keeping intersection point constant
?new context for fade intersections
?support optional snapping for all fade/crossfade behaviors
•Cursors:
?new cursors for resizing the extended mixer (extmix_resize, extmix_multiresize, extmix_allresize, extmix_section_resize, extmix_multisection_resize, extmix_allsection_resize)
?support for colors in custom cursor images
•Grouping:
?doubleclicking track vol/pan/width labels now resets using grouping/ganging
?improved volume fader grouping behavior when some faders are at -inf
•Item mouse hit zones:
?allow mouse to target buttons and fades even if another media item is overlapping
?mouse targets the fade curve by default (can be disabled in preferences)
?option to always show fade-in/fade-out handles
•JS:
?improved font display on win32
?reduced fx initialization interrupting audio
•OSX:
?fix for render-drag problems with external drives
?REAPER.app and ReaMote.app now have signatures for OSX 10.8
?render-drag to a new file outside of REAPER (commdand+opt by default) prompts before overwriting an existing file
•About: fixed usage statistics being reset when switching between 32/64 bit
•Actions: option to stop playback at end of loop
•API: added PreventUIRefresh which allows scripts/plugins to disable and reenable many UI updates during processing
•DDP: fixed MD5 generation on OSX 64
•FX: improved threadsafety in certain instances
•LAME: support loading LAME DLLs from UserPlugins path, improved prompting
•MIDI: fixed items that would not play in certain rounding instances
•MIDI inline editor: fixed buttons when zoomed in
•OSC: fixed FX parameter feedback for inactive tracks
•Pan: track pan value can be manually entered in track controls dialog
•Pans: manually entered values like "R50" and "L25" are accepted, in addition to "50%R" and "25%L"
•Project bay: fixed loading of bays in certain instances
•Project save: support for adding multiple project versions to rpp-bak files, choosing version on load
•ReaControlMIDI: automation support for enabling/disabling bank/program select and CC sliders
•Render: fixed saving render presets in different categories (bounds, output, all settings)
•ReWire: further improved shutdown/device unload sequence to better handle panels that prompt before exiting
•Routing windows: space passes through to main actions, for keyboard navigation use shift+space
•Sends: volume/pan values can be manually entered in I/O dialog
•Snap to grid: don't snap to grid lines that are more than 1/4 screen width away
•Tempo envelope: more consistent behavior when adding/deleting tempo markers when project timebase is beats
•Toolbars: fixed crash when using certain strings as custom toolbar button text
•Video: improved rendering accuracy near end of render when using resampling
•VST: fixed audioMasterTempoAt accuracy in certain instances
•Windows: installers now have authenticode signatures
Reaktionen: keys, Buanna, sonnie und 3 andere
Wow, da hat sich ja einiges getan.
Sehr schick!
Gerade den jetzt erst gefixten Drag-Export hätte ich neulich gut brauchen können.
Jetzt müsste nur noch das Auswahlverhalten von Spuren im Mixer etwas verbessert werden.
Und ein Ding das den Pan bei zwei ausgewählten Spuren mit gedrücktem Mouse Modifier in entgegengesetzte Richtungen regelt.
Dann wär ich ziemlich wunschlos glücklich.
Das geht bereits bei gruppierten Spuren.
juhuuuu!
Klingt alles gut. Mein lang erhofftes Area-Selection/Marquee-Tool ist immer noch nicht dabei. Und "CMD + OPT+ Drag" sollte endlich mal für mehrere Clips möglich sein. :o
noch ne kleine Ergänzung zum Eröffnungspost:
Auf der Reaper-Seite steht da noch "Next stop, Noon in Paris" dabei und es wird im pre-Forum gemunkelt dass da 'was Großes' (MIDI ?) mit dem nächsten Release kommen wird. ;)
Wir werden sehen...
Ja, schon.
Aber man muss dazu erst Grouping-Parameter in einem extra Dialog setzen und dann Spuren zu einer Gruppe hinzufügen oder wieder daraus löschen...
Das ist nicht besonders "rapid", und kein Bisschen dynamisch.
Spur #1 markieren, Spur #2 markieren, wird Pan bewegt bleibt alles so wie jetzt, wird SHIFT+Pan bewegt, dann bewegen sich die Pans entgegengesetzt.
Wäre auch mit mehr als 2 Spuren denkbar.
...aber dazu müsste man erst mal problemlos die Spuren auswählen können... :)
strg+linksklick wählt mehrere spuren aus. shift+linksklick zum auswählen aneinanderliegender spuren.
