Reaper 4.151
Ein neues Update vom 26.1
4.151:
OSX: fixed support for 10.4 (broken in 4.15)
ReWire: fixes for older versions of ReWire.bundle installed
ReWire: do not install ReWire.bundle v2.6 on OSX 10.4 (since it does not work there)
ReWire: (to correct ReWire not working on 10.4 after 4.15, remove /Library/Application Support/Propellerhead Software/ReWire/ReWire.bundle, then run REAPER 4.151/ppc to install correct version of ReWire.bundle)
Track manager:
double-click track number to scroll track into view
MIDI column (double-click to open all track MIDI in editor)
action to delete selected tracks (via menu or delete key)
changing record-arm state clears track auto-recarm
doubleclick on toggle columns works properly
drag tracks in manager to rearrange tracks in project (optional)
fixed remembering previous window location on OSX
if track MIDI is already open, double-click MIDI column to close
mute/solo/record-arm changes respect grouping (shift held overrides)
option for filter to hide child tracks only if the folder parent is hidden
option to auto-scroll to selected track when mirroring selection
right-click FX column to open individual track FX
right-click header to show/hide columns
set last touched track when selecting from the track manager
set track colors
Region manager:
delete key removes regions
display time in project timeline format
edit region/marker names in place
optionally display project markers
seek when selecting a marker or region (optional)
Project bay:
fixed action to force refresh
list offline FX
option to zoom/scroll to selected items when mirroring selection
usage menu selects and scrolls to media items
ReWire:
updated to ReWire 2.6
OSX and Win64 now install ReWire libraries if necessary
support for loading 64 bit ReWire devices
support for running 64 bit REAPER as ReWire slave (requires 64 bit host app, for now at least)
API:
added simple functions to safely access take and track audio
extensions and ReaScript can store/restore simple global state (GetExtState, SetExtState, etc)
extensions can add functions to ReaScript
Bridging:
avoid unnecessary delays when bridge process failed to launch
OSX support for bridging/firewalling 64 bit VST/AU
Memory metering:
improved Win32 memory meter accuracy
option (enabled by default on 32 bit) to warn when memory use is high
Parameter modulation:
fixed switching between tempo-synced and unsynced LFO
no minimum or maximum for typed-in LFO speed
ReaScript:
Python loading improvements
separate custom path preferences for 32-bit and 64-bit REAPER
Render dialog:
remembers last window position
saves changes even if window closed without rendering
Screensets:
update track manager when switching track views
save/load TCP visibility with track views
TCP/Mixer:
immediate feedback when sweep recarm/mute/solo controls across multiple tracks
sweeping mute/solo/record-arm respects grouping (shift held overrides)
sweeping record-arm buttons clears track auto-recarm state on mouseup
Track templates:
support for saving envelopes in templates
option to offset imported template items (and envelopes) by edit cursor
Windows:
64-bit build now compiled with ICC
better ASIO device selection when running both 32-bit and 64-bit REAPER on the same machine
Actions: relative item positions are preserved when moving item start or end
AU: fixed wet/dry control on default pin mappings
Auto recarm: faster changing of recarm state when operating on many tracks
Config import/export: UI improvement, added sections for chanmaps, scripts, menusets
Control surfaces: don't create undo points when any surface has touch state set
Envelope editing: fixed envelope point selection following time selection when option disabled
Filters: support for NOT and OR keywords (upper case, ORs have lowest precedence, so a b OR c d NOT e means (a and b) or (c and d and not e)
Freeze: fixed actions to freeze through last selected FX
Media item properties: immediately update properties window on apply
MIDI editor: fixed hang when entering grid size of zero
Mixer: action to show/hide children of selected folder tracks
ReaTune: clear/update analysis on demand in the manual correction tab
Regions: improved timesignature handling when duplicating regions
Take lanes: option to display empty lanes is now global, not per-project
Track recording settings window: fixed potential crash under certain instances
VST: fix for saving presets for plugins with non-automatable parameters
