Changes: Leaps and Heaps
* MIDI editor:
o action to reverse events also reverses CC, works in event list view
o actions that target a CC lane will target the top lane if no CC lane has focus
o advance edit cursor correctly after paste preserving position in measure
o better blink cursor appearance
o clicking to the left of a CC lane will set focus to that lane without deselecting notes/CC
o fixed CC events on one channel erasing events on other channels when moving CC with notes
o fixed splitting notes in looped MIDI items
o fixed step input actions when inserting X semitones below the current note
o immediately refresh event list when correcting overlapping notes/CC
o option to disable single-click selecting CC events
o paste preserving position in measure will not paste duplicates
o quantize, humanize, event properties, and filter windows stay on top of the editor
o swing grid support
o swing grid strength is set/edited by dragging handles on the upbeat grid lines [demo]
o text box for manual entry of swing strength
o when correcting overlapping notes, also correct CC events at the same time/channel
o when correcting overlapping notes/CC, always preserve the selected note/CC
* Custom colors:
o action to reset random color generator (also resets default.palette if it exists)
o if default.reapalette file exists, use those colors instead of random colors
o default.reapalette (resource dir): text file of R G B values, one color per line
o organized default custom color menu entries
o preference for media item background tint strength, for selected/unselected media items [demo]
o preference to automatically color any recording pass that adds takes to existing items [demo]
o support for setting all takes created in the same recording pass to a custom color [demo]
o support for setting custom colors per-take
* MIDI quantize:
o actions to quantize note position, or position and end, to grid
o added actions and options to quantize notes only, or all events
o added bypass checkbox to quantize dialog
o checkbox to fix overlaps on commit
o notes will move with grid changes if quantize dialog is open when changing grid or swing [demo] [demo]
o overhauled quantize dialog
o when quantize grid is set to editor grid, quantize swing setting is linked to editor swing
* OSX:
o better text field coloring
o fixed 2GB+ file peakfile generation/reading
o fixed a few graphical glitches relating to docked windows
o selecting default system devices now allows differing input/outputs
* Recording:
o organized options for behavior when recording over existing items
o recording over existing items can split the old items and add takes, create new items, or trim existing items [demo]
o ensure that loop recording creates correct length files when "add new files on loop" enabled
o fix for loop recording sometimes being slightly off the loop edges
o new preference to discard incomplete first/last takes if at least one full loop was recorded [demo]
* Takes:
o action to activate take under mouse, mapped to "Y" by default (for "yes")
o media item drawing optimizations
o media items can be locked to the active take (to prevent mouse clicks from switching takes) [demo]
o preference to link or unlink all takes when editing start offset (slip editing) [demo]
* Tracks:
o "Options/Show overlapping items in lanes" creates as many lanes as necessary [demo]
o when showing items in lanes, items whose audio will mask other items are drawn in a higher lane [demo]
o automatically remove tracks created by accidentally moving an item down too far [demo]
o added preference to remove or retain tracks created by moving an item below the last track and back
* Automation:
o higher recording speed for FX parameter automation
o refresh track volume/pan sliders when deleting a track envelope in read/write modes
* Color theme:
o added themeable colored bars to optionally display on selected items, active takes [demo]
o added themeable colors for MIDI note/CC text colors (light and dark)
* API: allow extensions and ReaScript to get/set take custom colors, recording pass ID
* Custom menu editor: action list automatically switches to the correct section when changing menus
* Envelopes: drawing optimizations when zoomed out
* External sync: option to only use external sync on playback or recording, or both
* Master VU: fixed inaccurate RMS meter calculation with some window/audio buffer sizes
* Media items: draw media source end notch slightly differently for unlooped items [demo]
* MIDI: fixed MIDI notes sometimes not being played when coinciding exactly with a time signature change
* Nudge/set: checkbox to preserve relative item positioning in set mode [demo]
* Preferences: new tab for path settings (default render path, default recording path, alternate peak cache path)
* ReaControlMIDI: fixed reading .ins files that contain trailing blank lines
* ReaGate: checkbox to invert gate output (when loud, duck wet signal vs dry) [demo]
* Scrollbars: improved zoom button sizing
* Toolbar: refresh custom toolbars after linking/unlinking loop points and time selection via preferences
* Transport menu: fixed checkmarks on submenu items (such as external sync, etc)
* Video: preliminary support for flip/rotate of video (video source properties) [demo]
* VST: inform plugins if transport repeat is enabled
* Windows: better audio device closing behavior when minimizing REAPER and stopped
* MIDI editor:
* Custom colors:
* MIDI quantize:
* OSX:
* Recording:
* Takes:
* Tracks:
* Automation:
* Color theme:
