Oeksound Bloom
Oeksound News Bloom Plugin​
Bloom is an adaptive tone shaper. It analyzes the character of a signal and applies corrections to the perceived tonal balance for a more even and refined sound. This lets the user shape the tone and character of a track, for example, by adding warmth, brightness, or clarity. Bloom's adjustments are dynamic and context-aware. This makes the plug-in quick and intuitive to use and helps keep the material sounding natural even when making radical changes.
A 20-day trial license is available for testing and ensuring compatibility. To start a trial period, simply download and install Bloom and open your DAW. You should be presented with an option to try Bloom. Alternatively, request an automatic trial license deposit directly onto your iLok account using this form.
macOS Sonoma 14.4 bug (AU plug-ins)​
We are aware of a major plug-in scanning bug concerning PACE / iLok protected AU plug-ins on Apple's latest release of Sonoma, 14.4.
So far, we have gathered that (at least) these requirements have to be met for the bug to appear:
  • macOS 14.4
  • Logic Pro or GarageBand (other DAW's don't seem to be affected)
  • iLok-protected Audio Units (AU) plug-ins
  • Running under Apple's ARM architecture
  • On M2 or M3 hardware (M1 does not seem to be affected)
If you are on an M2 or an M3 machine and rely on AU plug-ins, we advise against updating your computer to macOS Sonoma 14.4 until the issue has been fixed.
If you have updated to Sonoma 14.4 and are facing this issue, running your DAW with the Rosetta framework is the current workaround. You may need to rescan your plug-ins after switching to Rosetta.
Reaktionen: o))), petera, RK79 und eine weitere Person
Eieiei ... diese Hintegrundfarbe
Barbie empfiehlt Bloom. Aber interessantes Gerät, wird mal näher angesehen.
Oh, Alda, 199,00 regular... nä!
Reaktionen: Ethersis, markrec und Schlumpfpeter
Scheint schon cool zus ein, habe mit Equaliser von wavesfactory allerdings schon ein ähnliches Plugin.
Reaktionen: RK79
Sehr interessant... soothe als auch spiff sind unglaublich praktische Problemlöser für den Mischer, der öfters mal Tracks bekommt, die man irgendwie retten muss oder wenn man mal etwas anderes sucht (z.B. trebliger verzerrter E-Bass ohne Saitengeklapper... wer hätte vorher an sowas gedacht) oder generell jemand beim recorden was versemmelt hat.
Sie nehmen sich interessanterweise auch gegenseitig nichts, wie ich anfangs dachte, beide haben im richtigen Moment genau ihre Kompetenz. Bloom scheint tatsächlich das Dritte im Bunde zu sein. Auch dieses Teil wird/sollte nicht immer und überall einzusetzen sein, aber im richtigen Moment ist es dann kaum zu ersetzen.
Oeksound macht schon super gutes Zeug.
Mit dem Soothe kann man echt viel noch rausholen. Dabei benutze ich Spiff aber öfter, grade bei Vocals, in Kombination nach stärkerer Kompression.
Beide sind auch fester Bestandteil meiner Chain
Bloom werd ich definitiv ausprobieren
Reaktionen: petera
Ich nutze Soothe auch oft....kenne kein vergleichbares Tool. Toller Firmenansatz neues zu kreieren und nicht die 100ste Kopie irgend eines Klassikers.
Reaktionen: petera
Ich habe den Bloom getrialt. Eigentlich ein cooles Plugin, mal gefällt, was es macht, mal nicht so, dann fliegt es wieder raus. Also grundsätzlich schon ein Teil, das man gerne im Arsenal hätte für den ein oder anderen Fall.
....wäre da nicht der Preis.
Für ein "echtes" Werkzeug wie Soothe durchaus gerechtfertigt, sind 200 Euro für Bloom eine echte Kauf-Bremse.
Reaktionen: Schlumpfpeter
Probier mal Vitamin Waves aus finde es auch sehr gelungen und ich finde das es ähnlich ist aber anders 😃
Reaktionen: Dodo_I
Das ist mir zu alt. Ich hatte das sogar mal, glaube ich, im Rahmen des Gold Bundles, das eines Tages nicht mehr lief. Waves Central habe ich vom Rechner gelöscht. Ich glaube auch, dass Vitamin mit dem Bloom nichts gemeinsam hat.
Vielleicht mache ich die Kohle tatsächlich locker für den Bloom. Wird langsam langweilig, nur noch so Pfennigfuchser-Plugins zu kaufen.
Reaktionen: RK79
Dann Kauf dir Gain aim Pro finde das sehr gelungen 👌
Ich hole mir Bloom. Aber danke für die Vorschläge!
Ich bereue es, soviel Geld ausgegeben zu haben für Bloom. Ich frage mich sogar, wofür es da ist. Was macht es eigentlich? Dynamisch EQ-Bänder anheben und absenken? Dafür so eine teure Software?
Gibt es hier im Forum Leute, die auch Erfahrung haben mit Bloom?
