NI Battery 3.2 Update
  • Ersteller Ersteller genesysx
genesysx
genesysx
Ich glaub es hat noch keiner gepostet, darum hier mal die Info:
Dear BATTERY user,
We're pleased to announce that the BATTERY 3.2 update is now available for free download. The update contains several new features and workflow improvements, plus some fixes. Please make sure to read the Important Note below.
You can download the update via the NI Service Center or the Online Update Manager.
Main new and improved features:
New "Drum" mode in Saturator effect, which was designed for use with drum sounds. This new mode is especially useful on acoustic drums, but provides a generally louder and thicker sound on all kind of drums and samples
New "Default Kit" option enables you to load your preferred MIDI assignment, Cell names, Cell matrix size etc. automatically on start-up
New zero-latency convolution engine with optimized performance for low-latency settings, featuring a new latency-free setting for 100% sample accurate timing
Numerical parameter value input: The parameter values for almost all elements on the BATTERY 3 user interface can now be entered from your computer keyboard
New Import formats: Akai MPC 5000, Alesis Fusion, Drumagog, Korg Triton, Roland Fantom, Yamaha Motif
Mac OS X: 64-bit VST support
Mac OS X: 64-bit support for REX import
Bug fixes:
Fixes compatibility problems with Mac OS X 10.7 "Lion"
Fixed crash when learning MIDI assignments in Automation Page
Improved File Browser response
Mac OS X 64-bit: fixed crash when resolving samples in a host
We strongly recommend downloading and installing this update to ensure the best possible user experience and reliability.
Important note:
Since BATTERY 3.2 is now based on a new file format, kits and cells saved with BATTERY 3.2 cannot be loaded with previous BATTERY versions. Please be sure to backup your files and important projects before saving with BATTERY 3.2
Mac users: This version requires an Intel Mac and Mac OS X 10.5 (or later)!
Best regards,
Your Native Instruments team
damit ist die bis vor kurzem noch als öffentliche betaversion bezeichnete version 3.2 als entgültiges update 4free zu haben
Reaktionen: Bumblebee
Danke für den Hinweis!
Danke für die Infos.
Wen's interessiert: Der DVD-Lernkurs wird nach meinen Infos einen Lernkurs für Battery anbieten. Leider steht noch nicht fest, wann es soweit sein wird.
