MASCHINE Update (2.8.0) verfügbar
Austria
2.8.0 — 2019-02-21
ADDED Sounds.com Integration
Browse on Sounds.com, create your own collections of loops and one-shots, and sync the collections with MASCHINE. To make use of this feature, you must enable the "Download to All NI Apps" feature on the Sounds.com website. This can be found in your account settings, which can be accessed at this URL: "https://sounds.com/account/overview".
CHANGED There is now a single button for toggling the Browser between the Factory and User Libraries
CHANGED Samples are now cataloged in separate Loops and One-shots tabs in the Browser
For this version, all User Samples will be located in the One-shots tab of the Browser, regardless of whether they're tagged as Loops or One Shots.
IMPROVED Instruments, Loops, and One-Shots in the Factory Library will have their tags updated to the new NKS 1.5 format
ADDED Previews of loops selected in the Browser will be played in sync with the current project
When a loop is selected with Prehear turned on, it will begin playing immediately in-sync with the project if transport is running. If a loop preview starts part-way through the loop, the loop will play once more for its full length to ensure you get to hear the entire loop once in context with your project.
IMPROVED Filters and product selections will be remembered when switching between content types and Factory/User Libraries in the Browser
ADDED Browser content synchronization between multiple running instances
When running multiple instances of MASCHINE, either as Standalone and/or as a plug-in, updates to the Library will be synced across the instances. For example, if you delete a sample from your User Library in one instance, the sample will no longer be present in the other instances. Similarly, if you save a preset in one instance, that preset will then be available in the other instances, too.
ADDED Setting of Sample Start and End points from MASCHINE MIKRO MK3
Fine adjustments can be made by holding SHIFT while rotating the encoder.
ADDED When Browsing with A-Series keyboards, you can now jump quickly to the results list by holding SHIFT and pushing right on the 4D Encoder
ADDED When Browsing with A-Series keyboards, you can fast scroll through the Browser results list by holding SHIFT and twisting the 4D Encoder
ADDED Mute and Solo Sounds & Groups from A-Series keyboards
Sounds are muted in TRACK mode while Groups are muted in IDEAS.
ADDED Adjust Pattern Length with A-Series keyboards
Press the 4D Encoder on a Pattern in IDEAS. Twist for 1 bar increments, or hold SHIFT and twist for finer increments. Press again to set.
ADDED Clear patterns from A-Series keyboards by holding SHIFT and pressing STOP
IMPROVED Authorization system upgraded to RAS3
Existing RAS2 serial numbers will authenticate in the new RAS3 system automatically.
IMPROVED The LED feedback of the Pad Input Mode buttons has been improved for MASCHINE MIKRO MK3
IMPROVED Edits made to samples in the Factory Libraries will be saved to the Standard User Directory
FIXED MASCHINE would crash when connecting or disconnecting a microphone to the MASCHINE MK3
FIXED Pad Sensitivity was not saved for MIKRO MK3
FIXED Brightness slider would do nothing on MIKRO MK3
FIXED Could not change sounds while Browsing with Prehear disabled on MIKRO MK3
FIXED Pressing Undo on MASCHINE MK3 after recording a take now clears the waveform from display
FIXED Lit state of several buttons would appear stuck on MASCHINE MK2
FIXED KOMPLETE KONTROL S-Series would show incorrect Lightguide state for some plug-ins
Reaktionen: querfisch, TheSarge, dhinda und 2 andere
man schmeisse aus der Liste mal die ganzen MK3 & A-Series Punkte raus, dann bleibt aber wenig
jaja, klingt wie "immer was zu meckern" aber querchecked mal und ihr werdet sehen, daß ich leider Recht habe :schaem: ausser man findet die Sounds.com-makes-more-money-Integration als wunderbar :rolleyes:
Reaktionen: KDthe2nd, Supercreative und dhinda
So wie es jetzt kam, war es leider zu erwarten. Man wollte seitens NI halt unbedingt diese Sounds.com Plattform befeuern. Viele Nutzer sehen diese momentan als nicht bis wenig gewinnbringend. Ich gehöre dazu. NI sieht das aber ziemlich sicher rein wirtschaftsorientiert. Ob der Kurs funktioniert wird sich zeigen.
Ich hoffe, es geht jetzt mit der Entwicklung wieder in die richtige Richtung.... mal sehen wie lange es dauert.
Reaktionen: KDthe2nd und TheSarge
Hat schon jmd aktualisiert?
Gut finde ich die Loop-Kategorie im Browser. Das erzeugt noch mehr Übersicht beim Browsen.
Wie bekommt man da seine eigenen (User-Library und nicht die von Sounds.com) rein?
Würde mich auch mal interessieren :schulterzuck:
Hab jetzt mal "upgedated"... weil es mich interessiert hat.
1.) Sample in User-Library auswählen
2.) Content Type des Samples im Tag-Editor ändern
3.) Im Browser unter der Loop-Kategorie wiederfinden
Geht natürlich in ähnlicher Form auch alles ohne die aktuelle Version.
Ich finde es im Browser aber noch übersichtlicher.
Reaktionen: dhinda
Update eingespielt. Beim ersten Start wurde die Datenbank neu aufgebaut. Hat auf meinem System 1,5 Stunden benötigt.
Soweit aber alles ok.
Reaktionen: TheSarge
Reaktionen: dhinda, TheSarge und KDthe2nd
