Jemand eine Ahnung wie man dieses Plugin in Cubase routen könnte bzw welches Tool man dafür verwenden könnte?
http://madronalabs.com/products/virta
Scheit ziemlich interessant zu sein, erfordert allerdings ein etwas anderes Routing als herkömmliche Plugins ...
Zitat "Unfortunately Cubase did not get a lot of attention in testing. Nobody seems to know a good way to use it. I may have to make an audio instrument version for Cubase compatibility."
Aus dem Manual:
"If you’re using Virta with audio input only (no MIDI or OSC input), you
can go ahead and simply drop Virta onto an audio track in your DAW.
Once you’ve done that, you can enable recording or input monitoring
for that track, start pumping in the audio of your choice, and you’re off
to the races. However, for many uses, you’ll want both audio and MIDI
or OSC to be able to flow into Virta."
http://madronalabs.com/media/virta/images/VirtaManual.pdf
Sabler
Aus dem Manual:
Sabler
