Cubase Update 12.0.30 ist raus
  • Ersteller Ersteller Gast92251
G
Gast92251
Guest
liest sich gut. (Ich trau ja eh keiner Nuller-Release Version über den Weg) :smil451c7211b9e19:
Performance and stability issues​
The 12.0.30 update addresses a couple of performance issues. These issues could occur when closing the application.
We have also improved the performance when working with Vienna Pro Ensemble.
We will continue to investigate performance issues on specific systems and provide additional improvements in future updates. We still rely on your reports, so please get in touch with us in the Steinberg Forum if you are still experiencing issues after this update.
Plug-in blank space issues​
When opening and working with plug-ins, blank spaces could appear to the left/right side of the plug-in panel. We addressed this issue in this maintenance update.
We have improved the following features and functionality:​
Editing​
Editing time-stretched clips in Musical Mode now works as expected.
Moving Chord Events with the Range Selection tool now works as expected.
Switching from the Time Warp tool to other tools no longer changes the format of the timeline unexpectedly.
Recalling Project Logical Editor presets now works as expected.
The selection tool in the Sizing Applies Time Stretch mode works as expected when changing the algorithm in the preferences.
Adding warp markers to multiple selected events with the Free Warp tool now works as expected.
Miscellaneous​
The Track Controls Settings window now works as expected.
Importing AAF files no longer causes error messages on Macs which run on Apple silicon.
When exporting selected tracks that contain audio clips with the ARA extension, error messages no longer appear.
When using ARA extensions on AIFF clips, processed audio files no longer sound distorted.
The ID and Description labels for marking events are no longer swapped.
Adding Ambisonics channels in the MixConsole now works as expected.
Using the MixConsole Reset Channel function on an output bus now works as expected.
VariAudio segments in the Sample Editor are colored correctly, according to the chord track.
Presets can now be loaded from the right-click menu in the Channel Settings window as expected.
Vertical scrolling in the Sample Editor when using VariAudio now works as expected.
The MIDI Remote mappings for the Control Room now work as expected.
The items in the Mapping List of the Mapping Assistant are now sorted correctly.
Performance​
We have improved the performance when closing projects.
We have improved the performance with Vienna Pro Ensemble plug-ins.
The Roomworks VST3 plug-in now works as expected.
We have improved the user interface responsiveness when showing or hiding automation tracks in large projects.
Closing the application in Windows no longer takes an unexpectedly long time.
Stability​
We have improved stability in the following areas:
when importing track archives with video tracks
when importing tracks from projects
when working with VariAudio
when working in the Score Editor
when working with Audio Alignment
when working with network drives
Video​
The network connection to the GoPro VR Player can be established as expected.
The timecode overlay in the video player window and in exported videos is now as accurate as intended.
Reaktionen: Vast, musikertimo, Gelöschtes Mitglied 91366 und 3 andere
endlich wieder Plugins ohne Flügel
Reaktionen: terrablue und Glutamatjunkie
ui, da haben sie sich aber vielen Punkten gewidmet
jetzt fehlt (für mich) nur noch ein Update-Deal ~50€ und ich springe auf den 12er-ICCubase auf 🚄
ach du meinst die 1,5m-Abstandhalter links und rechts :green:
Ja genau. Spectrasonics hatte schon vor ein paar Wochen den Bug auf ihrer Seite gefixt. Dort wurde der QC-Schalter nicht angezeigt, wie bei Massive X & Co.
Reaktionen: Gast92251 und TheSarge
OK.
Schön langsam fällt der Schaum zusammen.
Könnte sein, dass ich jetzt umstelle und mir den traditionellen Hazzle antue...
Richtig Bock habe ich keinen, aber man muss auch irgendeinen Standard halten - selbst wenn man ihn nicht braucht.
OK.
Doch, du brauchst!
Doch, du brauchst!
Hnnnnjääähhh...
Meist aus dem gleichen Grund, weshalb man in der Schule zu rauchen angefangen hat :)
Man will irgendwo auch mitreden.
95 % von dem Kram der mir zur Verfügung steht brauche ich nicht und ich muss mir extra einen neuen Stil angewöhnen, damit ich es hernehmen kann... ?
Also die Lösung ist dann meist vor dem Problem da und man lernt sich erst die neuesten Probleme, damit man sie mit den brandneuen Tools dann auch spielend meistern kann (angehauchte Fingernägel am Revers abpolierend).
Brilliant!
Und dann kann man drüber reden... ;-)
Und auf die, die das nicht haben, kann man dann herabschauen.
Reaktionen: Glutamatjunkie und TheSarge
Oh eine ganz unangenehme Geschichte.
Da hab ich mir meine Augenbraue abgesägt, weil ich dachte hey es ist doch viel cooler die Zichte mit einer zwanzig Zentimeter großen Flamme anzuwerfen.
Hat einer von euch das Problem, dass das umschalten der Presets große Spikes verursacht? Keine Aussetzer.
Reaktionen: TheSarge
Moin im Steinberg Forum Deutsch und Engl gibt es wohl eine Menge Probleme nach dem Update auf 12.0.30 plötzlich sind da die Lizenzen verschwunden?! Lösung scheint zu sein den Activation Manager zu updaten, ich hatte auf 2 Rechnern keine Probleme damit
und ich merke das ich all die Probleme die ihr hier habt bei mir nicht auftreten, wohl weil ich all das nicht mache bzw brauche
ich hab mir grad das Tut von Holger gekauft.
leuchtet doch ein. So haben es die C12 Freewarez-Nutzer wenigstens etwas schwerer: Panik ohne Ende! :tears-of-joy: Sicherlich schiebt die osteuropäische Kräckergilde eh schnell was nach. LOL.
Reaktionen: Rescue und Glutamatjunkie
Seit Cubase 12.0.10 hatte ich bei dem einen oder anderen Plugin verlängerte Ladezeiten, die dann auch beim Speichern des jeweiligen Projektes aufgefallen sind. Punch2 von Rob Papen beispielsweise brauchte mehr als 10 Sekunden, bevor es angezeigt wurde und bedienbar war. Das ist mit 12.0.30 behoben. :yeah:
Der Steinberg-Support hatte mich "damals" an Rob Papen verwiesen, heute habe ich den Entwicklern zu ihrer guten Arbeit gratuliert. ;)
Reaktionen: Glutamatjunkie, TheSarge und Gast92251
Eben ja nicht, dass ist ja das fatale. Anstatt jedes mal die Anwendungen zu knacken haben die nur einmal nen Emulator für den Lizenzmanager selbst geschrieben auf dem sämtliche unveränderte Originalversionen inkl. Wavelab, Nuendo, Spectralayers, Dorico, Halion usw. laufen. Da hat sich Steinberg echt ganz schön ins Bein geschossen und als legaler User kommt man sich da doch ein bisschen verarscht vor. Naja, wurscht...
doch, doch. Die illegalen Nutzer kotze da gerade. Weil die Knilche es nicht sofort checken. Natürlich werden Tipps vergeben, wie man das dann löst, aber erstmal bei vielen "No valid License found". LOL.
Im Gegenteil. So wird Cubase nur noch populärer und reiht sich ein mit den anderen schon seit Jahren längst gecräckten DAWs um S1 & Co. Die meisten Leute wollten schon immer lieber ein Cubase, mussten aber ein S1 nehmen, weil es das schon immer sofort gecrackt gab. Und einige dieser C12 Free Version-Leute kaufen dann auch regulär später mal ein Cubase. Sowas ist quasi gute Werbung für Steinberg. Lass die jungen Leute doch damit in ihrem Jugendzimmer rumspielen, in diesem Alter hat ja nicht jeder die Kohle für die große C Pro Version. Und Steinberg spart sich jetzt den ganzen Stress und mega Entwicklungsaufwand und die Tests für den ganzen Dongleschutz. Beide Seiten also Gewinner.
Reaktionen: Gast90407
Mal sehen ob nun auch die Probleme unter 4K behoben sind.
Aktuell sind mit der 12 erstmal viele viele bunte Mac-User dazu gekommen. Ist halt blöd, wenn man aus religiösen Gründen einen Rechner gekauft hat, der nur ein oder zwei USB-(C)-Ports hat... Da mussten die Jünger bislang was die Dongles angeht schon haushalten. Jetzt baumelt der iLok am USB-C-auf-A-Adapter, und Cubendo geht ohne, und da kommen sie angeschwirrt und lassen Geld in Hamburg. Freut mich, ein Stück weit scheint die Strategie aufzugehen. Ob das von Dauer ist - wer weiß.
