Cubase 6.0.7 maintenance update!
  • Ersteller Ersteller Gast92251
G
Gast92251
Guest
Ein Maintenance-Update für User, welche noch kein 6.5 auf dem Rechner haben.
Mon Jul 23, 2012
The 6.0.7 maintenance update brings the following improvements for Cubase 6 derivatives*:
Project: When importing and exporting track archives, marker tracks are now properly stored and restored.
Project: Project saving time is improved.
Audio: Selecting multiple mixer channels via SHIFT modifier no longer selects input/output channels accidentally.
Audio: Exporting a quad-channel audio mixdown to MP3 format no longer renders the application unresponsive.
Audio: Recalling a VST Connection preset while the Audio Export Mixdown dialog is open no longer renders the application unresponsive.
Audio Editing: After splitting a VariAudio segment of a shared clip, pressing the Cancel button in the "New Version" window no longer renders the application unresponsive.
Audio Editing: Editing an audio clip with VariAudio, then deleting it and undoing the whole operation now works as expected.
Audio Editing: Inserting silence into a selected range now works as expected if the selection end is directly followed by a signature change.
MIDI: Recording in MIDI Replace mode now works as expected at any project time.
Plug-in: When using the Mix6to2 plug-in, the first channel (volume left) is now fully automatable.
Plug-in: When using Cloner, automating the "Detune natural" button no longer mutes the audio signal.
Plug-in: Automating the Voices parameter in Cloner now works properly.
Plug-in: After saving and loading VST Presets, the bypass state of specific plug-ins is now recalled correctly.
Downloads:
http://www.steinberg.net/en/support/downloads/downloads_cubase_6.html
http://www.steinberg.net/en/support/downloads/downloads_cubase_artist_6.html
http://www.steinberg.net/en/support/downloads/downloads_cubase_elements_6.html
http://www.steinberg.net/en/support/downloads/downloads_cubase_ai_6.html
http://www.steinberg.net/en/support/downloads/downloads_cubase_le_6.html
cool...und ich dachte es wäre schon perfekt ;-) Thx!
Leider rennt das Update bei mir nicht. :(
Ist aber auch wurst, ich habe mit den aufgeführten Dingen bislang keine nennenswerte Probleme gehabt. Mich würde es nur freuen, wenn der zehn Jahre alte Pool-Bug endlich behoben würde. Aber auch den weiß ich mittlerweile meistens zu umgehen.
Tschö,
Steffen
wie gehtn der poolbug? mir noch nie was aufgefallen (aber ich benutz den pool auch nur wenig)
Ich hab gestern den Pool benutzt. Bei über 30 Grad gab es aber keine weiteren Probleme in diesem.
G
4K
mackie1402
mackie1402
synthpark
6K
clemenserwe
clemenserwe
G
7K
solokeyboarder
solokeyboarder
G
puppystudios
P
