Introsong
Run Cakewalk to update
New in build 30.04.0.450
- Various UI/Theming improvements
- Improved font rendering for lower DPI displays
- Custom Display Scale Slider (Experimental)
- The Display tab of the Preferences now features a slider to adjust the display scaling of the app independently from the global Windows display setting. Note that this feature is still in early development and there may be issues when applying a custom app value.
- Updated mouse cursors
- Fixed: Dragging EDS enabled plugin between different scaled displays can get stuck
- Fixed: Asserts when hitting play with External Insert
- Fixed: REGRESSION: VocalSync UI is broken at high DPI
- Fixed: Regression: Lane names cannot be resized
- Fixed: LCV zoom controls are inconsistent with the TV and PRV
- Fixed: When lasso selecting, always show the lasso cursor ("+")
- Fixed: Inspector advanced MIDI strip Patch Browser/Bank dropdown buttons disappear on mouse over
- Fixed: Do not take toolbar width into account when sizing plugin windows
- Fixed: REGRESSION: TV surround bus header high DPI layout issues
- Fixed: Loading workspace with Medium/Small Screenset Module causes it to fail to draw
- Fixed: Misc. Preferences font size issues with custom display scale
- Fixed: Misc DPI related plugin issues
- Fixed: Drawing notes in the Staff view uses the Copy cursor
- Fixed: Numerous "HUDNow" windows in the Task Switcher (Alt+Tab)
- Fixed: Some mouse cursors look blurry on high DPI displays (eg. 1440p)
- Fixed: Unacceptable PRV performance with user project
- Fixed: Keyboard Shortcuts in Preferences loads very slowly
- Fixed: Input Echo not retained after undo of delete track for Simple Instrument Track
- Fixed: Instrument Tracks do not retain Input Echo state when loaded from Track Templates
- Fixed: Archived MIDI track disables freeze on Instrument track unexpectedly
- Fixed: Moving comp split point in multi-tempo project alters next segment's start time
- Fixed: REGRESSION: Broken VST3 plugin sizing when dragging left/top window edges
- Fixed: Dragging velocity tails in PRV creates additional notes when muted clips are involved
- Fixed: Step Sequencer loads blank after loading pattern preset
- Fixed: Pressing Play with Now Time after Project End Marker disables Audio Engine
- Fixed: Control Bar Snap module should not show triplet/dotted buttons at medium size
- Fixed: REGRESSION: Crash when opening Step Sequencer with Custom Display Scale > 100%
- Fixed: REGRESSION: Long button text is displayed incorrectly in Control Bar Custom module on 96 DPI display
- Fixed: REGRESSION: ProChannel EQ flyout layout issues with Custom Display Scaling <> 100%
- Fixed: REGRESSION: Add Track flyout layout issues with Custom Display Scaling <> 100%
- Fixed: REGRESSION: Incorrect Console View track title text formatting on 96 DPI display
