Hat jemand die aktuellen Release Notes der Software zur Hand, finde grad nicht.
Changes from version 1.0.4:
WHAT'S NEW
New redesigned and clearer user interface for easier usability and faster browsing
New Librarian section to transfer and manage TONE MODELs and PRESETs using the new TONEX Pedal
PLAYER
Added Tuner
Added settings for Input and Output levels
Added multi-import and multi-export for PRESETs
Added choice of 10 new amp skins to select from the MODELER's collection
Added cab lock option to keep the same cabinet when browsing TONE MODELs.
TONE MODELs and PRESETs can now be browsed using the keyboard's up and down arrows
A cabinet can now be added to a TONE MODEL STOMP
Download numbers are now displayed for each TONE MODEL
MODELER
Improved MODELER's accuracy when modeling hi-gain tones
MODELER can now work at every sample-rate
FIXES
Fixed an issue that could cause the modeler to get stuck on Creating Network when modeling a TONE MODEL
Fixed an issue that could cause incorrect tagging at the end of a Modeling process
General reliability improvements
Changes from version 1.0.3:
Added 10 new DIs to preview PRESETs & TONE MODELS.
Fixed a bug that could cause a routing misbehavior while capturing TONE MODELs.
Fixed a bug that could cause bumps when changing PRESETs or TONE MODELS.
General reliability improvements.
Changes from version 1.0.2:
This version unlocks pre-purchased Tone Models Collections on the TONEX iOS app
Changes from version 1.0.1:
Fixed an issue that could cause inaccuracies when capturing TONE MODEL AMPs without a cabinet ("Amp" and "Stomp and Amp" TONE MODELs).
Improved by 30% the Advance Training timing.
Added up and down arrows to browse TONE MODEL AMPs and CABs.
Implemented gain reduction meter in the compressor module.
Fixed an issue that could cause crashes when using TONEX as a plug-in inside a DAW.
Fixed an issue that avoided sorting in ToneNET.
General graphic improvements.
