Rec0rder
One Take Wonder
das ding scheint so neu zu sein dass man selbst bei Eventide nix darüber findet..
kann man sich hier kostenlos abholen:
https://www.jrrshop.com/newfangled-audio-pendulate
Link zum Hersteller müsst ihr euch diesmal ausdenken
Freiwillige bitte vor !!!
Novel chaotic oscillator based on the double pendulum makes sounds you've never heard before, but will want to hear again
Wavefolder based on the one in the Buchla 259 Complex Waveform Generator, adding MIX and CUTOFF
Low Pass Gate based on the Buchla 292 adds controls for POLES and RESONANCE
Innovative modulation UI allows modulation over every control from the main page, allowing up to 169 simultaneous modulation routings
MPE support allows amazing control from innovative new controllers
Envelope and LFO each have multiple outputs generated at once, like a modular synth should
Modulation! Every mod output to every control means up to 221 modulation points in an intuitive single pane
Animations! The Double Pendulum, Wavefolder, and Low Pass Gate modules each have animations to show how each module responds to your input, and to modulation
Three unique color schemes to customize your look
136 Presets including artist presets from Matt Lange (Producer, DJ) and Matthew Wang (Composer Film/TV).
No iLok Required
macOS 10.9+ - AAX 32/64-bit, AU 64-bit, VST3 64-bit
Windows 8+ - AAX 32/64-bit, VST3 32/64-bit
