ESP Eclipse "CTM" ?
  • Ersteller Ersteller EOD
EOD
Hallo, nur eine Frage.
Was bedeutet bei den ESP Eclipse Modellen das CTM ??
Dank und Gruß
"The Eclipse II's are the USA versions with the shorter horn and 3 knob layout. The CTM Eclipses all have ebony fretboards, multiply binding, 4 knob layout and longer horn. Most the CTM's have gold hardware. The CTM's are made to look more like Les Paul Customs from the top side and are not released in the USA.
Both the Eclipse II's and CTM's have the thinner body with the belly cutout. The overseas full thickness ESP Eclipses are the only ones that have the same thickness as Les Pauls. "
