REAPER v5.980
Grummelrocker
Moderator
Ex-Rockstar
Teammitglied
v5.980 - July 11 2019
  • + ARA: handle ARA state load error without interfering with extension state loading [p=2151344]
    + Arrange view: avoid excessive redraws during some mouse edits
    + Envelopes: don't preserve relative differences between points when editing via action [t=222016]
    + Envelopes: fix inconsistency when loading projects with bezier envelope points
    + Envelopes: fix time selection edits that start at the beginning of a media item [p=2154450]
    + Envelopes: improve UI performance when recording send volume/pan automation [t=207384]
    + FX: fix potential crash on macOS/Linux when auto-switching visible FX chain [t=222841]
    + FX: fix ReaTune per-take FX tail issue [t=221956]
    + Jump to time: add support for jumping to relative time in earliest selected media item
    + Localization: improve alignment of various auto-resized controls when arranged in columns [p=2146661]
    + MIDI editor: handle converting multiple selected events between 2-byte and 3-byte messages [p=2154933]
    + MIDI editor: support copy/pasting events between CC lanes and channel pressure lane [p=2154852]
    + macOS: fix system Services menu [p=2150593]
    + macOS: use standard Window/Help menu ordering
    + macOS: add osx_max_open_files= reaper.ini tweak [p=2156238]
    + Media items: add optional per-item ruler display
    + Mixer: fix slowness when opening mixer [t=222728]
    + Mouse modifiers: fix preference to ignore targeting media item lower half [t=222080]
    + Mouse modifiers: improve handling of empty take lanes when targeting media item lower half [p=1683360]
    + Notation editor: fix chasing key signature changes when displaying multiple tracks [t=222703]
    + Notation editor: fix chasing clef changes when media items overlap [t=219859]
    + Nudge: fix issue with calling nudge-by-settings-slot before opening nudge window [p=2156424]
    + Peaks: do not set all media online after building peaks [t=222807]
    + Peaks: fix bug in waveform drawing with some themes and settings (5.979 regression) [t=222229]
    + Performance: improve low-latency behavior by avoiding destroying media buffers from audio threads
    + Performance: fix live FX multiprocessing issue with folder tracks causing media buffer underruns
    + Performance: reduce audio device underruns when pausing
    + ReaScript: simplify display of line numbers in IDE error messages [t=222740]
    + ReaScript: improve Python compatibility with unicode strings
    + Ruler: in frame mode, display one tick mark per frame when possible
    + Render: add option to render selected tracks via master
    + Render: improve use of $item wildcard when rendering project regions
    + Render: support $item and $track wildcards when rendering selected media items via master
    + Render: when rendering selected tracks or media items via master, also render children and receives [p=2151904]
    + Toolbars: improve automatic button images for various Set: actions
    + VST: limit preset dropdown to 512 presets of each type
    + VST: improve support for VST3 MIDI program change messages
Generated by X-Raym's REAPER ChangeLog to BBCode
Reaktionen: acblitzdc und sts
Bin ja gespannt, ob wir noch die Version 5.999 erleben, bevor die 6.0 kommt. :cool:
Reaktionen: BenBlutzukker
