Tonminister_V2
ReaScript
Download
- add drag and drop receive support with gfx.getdropfile()/gfx_getdropfile()
- allow deferred script execution to continue during modal windows triggered by MIDI
- fix SnapToGrid() for slightly-offscreen points
- StuffMIDIMessage() for control defers to process similar to a hardware MIDI event
- improve keyboard navigation for control surface configuration
- label AI properties sliders
- fix create shortcut for video processors
- fix truncated labels for insert chain actions
- fix memory error on musicXML import
- import files with .musicxml extension as well as .xml
- always import MusicXML files to built-in project MIDI, rather than file reference
- fix small UI positioning glitch
- fix memory leak
- update affected tracks when adding hardware outputs en masse
- repopulate channel selection list when track channel count changes
- optionally do not draw horizontal guides when moving items
- update CC lane combo boxes when loading note names
- fix $samplerate wildcard (uses render samplerate rather than audio device rate)
- improve item quantize and stretch marker snap behavior near tempo markers
- prevent deadlock when using SetObjectState() with certain state on track FX (SWS issue ID 992)
- do not inform VST3 of track channel changes by default, allow override for all instances of a plug-in or per-instance with channel count
Download
