Reaper 5.50
  • Ersteller Ersteller sts
v5.50c - September 16 2017
  • + Actions: automatically make capitalization consistent for non-localized action description strings
  • + Audio: allow frequencies up to 100MHz when using dummy audio driver [t=195153]
  • + Audio: avoid changing device samplerate to default samplerate when loading projects [t=193651]
  • + Audio: add option to flash transport status yellow on possible audio device underrun
  • + Audio: improve various playback/recording behaviors when using background project tabs [t=193849]
  • + Automation items: add automation item support, to contain, move, and transform portions of envelopes
  • + Automation items: items mask the baseline envelope, but overlapping items all affect playback
  • + Automation items: items may be pooled or unpooled, looped, stretched, skewed, and phase-shifted
  • + Automation items: items may be named, saved, and loaded
  • + Automation items: support separate baseline, amplitude, and looping for individual instances of pooled automation items
  • + Automation items: alt+drag in envelope lane (by default) to draw automation items
  • + Automation items: add automation item and automation item edge mouse modifier contexts
  • + Automation items: add actions to insert, duplicate, split glue, delete, etc
  • + Automation: prevent latency adjustment when playback is stopped [t=193321]
  • + Configuration: support import/export of more configuration files
  • + Envelopes: add envelope lane mouse modifier context, deprecate preference to respect envelope segment modifiers in envelope lane
  • + Envelopes: remove envelope lane click mouse modifier context, add envelope lane double-click context
  • + Envelopes: add mouse modifier to freehand draw envelope points respecting snap
  • + Envelopes: add actions to reverse envelope points, reduce number of points by half, insert envelope point ignoring snap
  • + Envelopes: fix a few non-working send envelope menu items [t=190902]
  • + Envelopes: add option to prevent mouse edits of single envelope points from moving past other envelope points
  • + Envelopes: preserve envelope curvature during "move envelope segment preserving edge points" edit
  • + Envelopes: preserve envelope curvature when moving points with media items, or within time selection
  • + Envelopes: preserve envelope curvature at time selection edges when initiating envelope segment edit within time selection
  • + Envelopes: improve behavior when freezing/unfreezing with send and pre-fx envelopes [t=195398]
  • + Envelopes: fix initial value when auto-adding FX parameter envelope [t=192204]
  • + FX: improve support for wet/bypass/VST3 parameter IDs on MIDI learn, TCP knobs
  • + FX: do not auto-increase track channel count when loading FX chains that have multichannel FX but were saved from stereo tracks
  • + FX: fix potential bugs relating to bypass/wet envelopes when loading automation and FX parameter counts change
  • + FX: fix issues related to user-preset navigation [t=195699]
  • + FX: add ReaCast, a shoutcast/icecast source plug-in
  • + FX: improve ReaEQ/ReaXcomp analyzer accuracy [t=194328]
  • + FX: fix project save of JSFX preset names that contain spaces
  • + FX: add mix-in and auto-update options to allow some spectral smearing capabilities for JSFX spectral_hold
  • + FX: improve display updates for some JSFX scripts
  • + Grid: sanitize grid values on project load/entry [t=190108]
  • + LAME: bundle libmp3lame 3.99.5
  • + MIDI: restore keyboard focus to piano roll after changing CC lane via dropdown
  • + MIDI: fix action to explode MIDI by pitch (and some related behaviors) [t=190905]
  • + MIDI: fix project MIDI export when project start time is not zero [t=194713]
  • + MIDI: fix project MIDI export SMPTE time when using ND timecode [t=194710]
  • + MIDI editor: handle click on track title exactly like a click on the activate icon in the MIDI track list
  • + Metronome: support triplets in metronome pattern [t=192992]
  • + NINJAM: improve cross-platform compatibility of clipsort.log import
  • + Notation editor: fix PDF export when "bracket tracks by folder" option enabled [p=1844292]
  • + Notation editor: preserve notation for non-displayed notes when edits are made with channel filter active [t=185286]
  • + Pan: allow very small track pans in fine adjustment mode
  • + Pan: display sub-1% pans with increased precision
  • + Pan: decrease media item properties pan snap-to-center threshold [t=190557]
  • + ReaScript: improve undo/update behavior for InsertTrackAtIndex(), DeleteTrack() [t=135573]
  • + ReaScript: avoid setting console focus on reaper.ShowConsoleMsg("")
  • + ReaScript: improve display updates for some scripts
  • + Sends: set focus for temporary single-send adjustment windows
  • + Spectrogram: add spectral editing support, action to insert new edit regions [YouTube]
  • + Theme: fix incorrect separators with grouped tracks [p=1874859]
  • + Undo: improve undo efficiency
  • + Undo: automatically make capitalization consistent for non-localized undo point description strings
  • + Undo: fix behavior when reordering FX with automation [t=191588]
  • + Undo: fix behavior with FX TCP parameters and learn [p=1845984]
  • + Undo: fix parameter modulation settings
  • + Undo: fix behavior when modifying stretch markers via swing grid
  • + VST: support VST3 extended functionality with Softube Console 1
  • + VST: improve macOS bundleExit VST3 compatibility
  • + VST: improve resize behavior of various plug-ins [t=193099]
  • + VST: send 10 channel speaker arrangements as user-defined [t=194176]
  • + VST: use VST3 parameter IDs for tracking envelopes/parameter modulation across sessions
  • + Video: fix rounding behavior with alpha-blended gfx_xformblit/gfx_deltablit
  • + Web Interface: add fancier.html
  • + Windows: increase FLS slots available on x64 for improved plug-in compatibility
  • + Windows: support receiving ASIO overload notifications
  • + macOS: add CoreAudio option to ignore project samplerate
  • + macOS: support receiving CoreAudio overload notifications
  • + macOS: improve scroll behavior of non-REAPER windows on 10.11+ [t=195544]
  • + macOS: improve mixer drag and drop behavior [t=190761]
  • + macOS: preserve parameter modulation window position when auto-resizing
Changelog - Pre-Releases
Generated by X-Raym's REAPER ChangeLog to BBCode
Also, das Spectral Editing halte ich primär für Spielkram - insbesondere wenn es um S-Laut Reduktion geht wie in diesem Beispiel. Den ganzen Aufwand kann man sich wirklich sparen, da Zischlaute (Rauschen) keine tonalen Anteile aufweisen. ;-) Ein guter DeEsser ist da einfach effektiver - und vor allem immens schneller. ^^
Die Automation items sind ganz nett, wenn man denn Elektro-Loop-Sachen mit wiederkehrenden Automations-Figuren bauen will und sowas dann braucht. Aber solange der Midi-Bereich eher rudimentär in Reaper ist, macht Elektroproduktion damit nicht gerade sonderlich viel Spaß.
Ein gutes Update, aber eben wieder mit viel Schnick & Schnack. Ich bin sogar noch auf V4.x., na mal schauen.
Hehe, bei Jon klingen die Automation Items echt komplex, Kenny bringt das ganze viel fluffiger rüber, finde ich. Trotzdem, Jon´s Videos sind ebenfalls klasse!
Diese neuen Features sind echt mächtig, Hut ab!
EDIT: Haha hammer, es ist bereits die 5.60 erschienen (als Pre-Release natürlich)! Die Jungs ruhen sich keineswegs auf ihren Lorbeeren aus, TOP!
