REAPER 5.27
Notation
- support PDF export
- add various minor improvements in appearance
Comps
- clear all comp/group names when creating new project
- improve handling of comp names with undo and cut/paste
- respect grouping when loading comp or moving active comp to top lane
- preserve comps when splitting items
- various bugfixes
FX
- add menu item to copy FX with automation, bound to ctrl+alt+C
- support drag and drop copy with automation via shift+ctrl+drag FX
- add Copy/Paste to mixer FX context menu
MIDI
- reduce Windows MIDI hardware output jitter
- import type 1 MIDI files with channel data in the tempo track
MusicXML import
- improve support for MIDI channels
- handle multitrack/multichannel import similarly to MIDI import
Ripple editing
- fix potential hang when using locked items and "locked items interrupt edits"
- improve locked item behavior when inserting/removing items
Undo
- rewrite undo history when renaming file via media item properties
- process any latent FX notifications when calling Undo_EndBlock() via API
Automation
- fix take envelope paste with take playrates
Groups
- improve handling of item group names with undo and cut/paste
macOS
- avoid attempted mkdir /Volumes/... when path does not exist
Peaks
- fix preview display with channel conversion while building peaks
Project bay
- improve handling of empty takes
Take lanes
- include selected+grouped takes when switching takes via lane
VST
- fix VST3 UI issues with various plug-ins
Windows
- improve handling of certain malformed paths
Download
