REAPER 5.21
v5.21 - June 16 2016
API
- Add GetSetTrackGroupMembership()
Accessibility
- Fix alt-key accessing main menu on Windows when arrange is in focus but mouse is elsewhere
- Fix generic slider keyboard support when slider mosewheels disabled
Actions window
- Improve resize drawing on OS X
Arrange
- Improve drawing performance when zoomed in on empty space between items
Auto-arm
- Fix potential UI issue when using auto-arm selected tracks
Automation
- Improve volume envelope panel tweaking behavior
FX
- Improve behavior when removing latent plug-ins from Monitoring FX/Record Input FX
- Run automation for FX with open configuration panels on otherwise empty tracks
JSFX
- Support ctrl+click of edit button to recompile/reset
MIDI editor
- Action to set note ends to start of next note will not shorten notes beyond the lesser of (grid size, 25% of original note length)
- Add default toolbar buttons to switch view mode
- Add "show/hide track list" to track selection dropdown
- Add action to select all notes at pitch cursor
- Add action to select all notes starting in measure
- Fix action to select all notes in measure
- Avoid sending excess all-notes-off on stop
- Display notation data in a dedicated list view column
- Disregard snap to key when in named notes (drum map) mode
- Enable "size to fit" behaviors for notation editor
- Fix disappearing events when using channel filter and list view
- Improve undo behavior with multiple context and various actions
- Improve CC120-127 handling in piano roll and list editor
- Respect key signature when displaying pitch names regardless of snap-to-key setting
- Optimize performance when navigating large MIDI items while using the MIDI filter
- Refresh editor immediately on moving notes left/right via keyboard action in non-active MIDI item
MIDI
- Avoid duplicate note-offs on stop in certain instances
- Fix export/glue of 1-byte text messages
- Fix incorrect tempomap rounding issue
- Fix potentially corrupt note-off velocities
- Increase imported MIDI file source lengths using MIDI end-of-track meta event if present
Media Explorer
- Fix tempo-match seek positioning for .wav with tempo information
Mixer
- Update track label number after duplicating track if not displayed in TCP
Notation editor
- Improve note editing when displaying paired staves and custom clefs
- Fix incorrect breaming in certain chord/time signature combinations
- Fix missing ledger line when using custom accidentals
- Handle some common beaming/grouping rhythm exceptions
- Prevent autodetection of triplets if non-triplet notes exist within the triplet bracket
OSC
- Fix comments in Default.ReaperOSC
- Fix track bank selection bug for last track in session
- Send tempo change notifications during playback
- Improve coreaudio device samplerate normalization introduced in 5.20
- Improve Audio Units keyboard support
Peaks
- Fix blank peaks on very-zoomed-out small items
- Improve various behaviors when rebuilding peaks
- Fix incorrect REX peak drawing when using all-slices, looped
Playback
- Improve output latency calculation when using project playrate
RS5K
- Avoid potential reentrancy related crash
- Do not offer RPP files in sample list
ReaControlMIDI
- Update log when opening UI
Routing
- Filter out invalid send-to-self on project load
VST
- Avoid sending duplicate note-off/pitch-reset messages on stop/flush
- Improve keyboard handling with Native Instruments plug-ins
- Support MIDI note names on multiple channels
Download
Na ja, die Entwicklung für so Aussenseiter-Betriebssysteme wie OS X geht halt nicht so schnell...
:L:
