Reaper 3.14, neue Version zum offiziellen Download
http://www.cockos.com/reaper/download.php
Changes: Rounding things out nicely
* Action: show/hide all floating windows
* API: added functions for sending commands to the active [g=32]MIDI[/g] editor window
* API: added register("command_id_lookup") to find extension actions
* API: added functions to retrieve track/take envelopes
* API: added MIDI_eventlist_Create, MIDI_eventlist_Destroy
* API: added GetSetTrackState, GetSetItemState, GetSetEnvelopeState
* API: fixed extension shortcut problem
* Automation: fixed action to set envelope lane fader from [g=32]MIDI[/g] controller
* Automation: more consistent behavior for new envelopes picking up the fader value in non-trim mode
* Auto-crossfades: fix for some crossfades not being reset when moving multiple items across tracks
* Batch converter: new facility to convert media in bulk, optionally applying FX
* Custom menus: main [g=32]MIDI[/g] menus can be customized, other improvements
* Custom menus: import/export/reset individual menus along with entire sets
* Custom toolbar: support adding extension actions to toolbar
* DX: fix for synths dropping the first [g=32]MIDI[/g] note
* Live performance: FX multiprocessing optimization
* Media item resampling/pitch shift modes: not switched when switching projects
* [g=32]MIDI[/g] editor: Fixed adding text/sysex events not extending source length when past end
* OSX: fixed issues with mouse focus in TCP
* OSX: nicer disk image
* OSX: various menu improvements/fixes
* OSX: preliminary video support
* OSX: alternate [g=77]VST[/g] cache/path config for PPC vs Intel
* Peaks: fixed recording peaks interpolation accuracy and corner-case crash when recording
* Prefs/Media/[g=32]MIDI[/g]: Improved behavior when all-notes-off when un-record-arming a track disabled
* Project/template file save: better detection and handling of failed disk writes
* ReaSamplomatic5000: Configurable per-instance resample mode
* Render queue: resizeable
* Track height: default for new projects can be set via File/Proj Settings/Save as default or Prefs/Projects/Default
* Track renaming: better support for tabbing through tracks when envelope panels visible
* Video: improved scrubbing support
* Video: handling of multiple items improved (later items, higher track numbers prioritized)
* Windows: Fixed font used in some dialogs for ClearType ([g=223]OGG[/g] rendering, etc)
Nebenbei:
SWS-Extensions für OSX (Tracklist, Mixersnapshots und vieles mehr.):
http://www.standingwaterstudios.com/
