Nexus 4 & BlackFriday
  • Ersteller Ersteller Gelöschtes Mitglied 23444
G
Guest
Was die V4 anders macht oder mehr kann, weiß ich nicht. Sie ist jedoch verfügbar :) Als Upgrade von Nexus 3 aktuell für ab 99,-€
Einige der Expansions sollen auch im Sale sein.
Ich dachte Nexus 3 ist doch grade erst neu rausgekommen aber das ist auch schon wieder 2 Jahre her, wie die Zeit vergeht...
Changelog for version 4.0.0 - 2021-11-26
new:
  • Front panel
    • The reverbs gained a "shimmer" effect.
    • Output scope is now synced.
    • Added new spectrum analyzer.
    • Added new spectrum analyzer (bars).
    • Added new spectrogram.
    • Added new vector scope.
    • Added new stacked spectrum analyzer.
    • The skins can now be selected from the three-dot menu.
    • Hovering over your avatar reveals sync state and statistics.
    • Your avatar now has a sync and online indicator.
  • Librarian
    • The search-field works for folders too now.
    • Folders can be added to favorites.
    • Folders are separated by headers, for a clearer overview.
    • The librarian has a history now, so if you get lost, you can go back easily.
    • The results are also separated by headers now, when sorted by category.
    • The preview on/off toggle is now next to it's volume dial, for quicker access.
    • The tag-display has been modernized.
  • Arpeggiator
    • The arpeggiator gained an fully interactive, zoomed out overview at the top.
    • A new option to "follow" has been added, so when zoomed in it follows the playback.
    • New editing options have been added (duplicate).
  • Modulation
    • The LFOs gained a view of their current shape and output value.
    • The Mod-matrix sources can now be "shaped" for more accurate control.
    • The Mod-matrix sources fields are now wider, allowing to read macro-names.
  • Effects
    • Effects can now be re-arranged by drag'n'drop.
    • Added "glitch" FX.
    • Added "ott" compressor FX.
    • Added "magnetic" insert FX.
    • Added "noise" insert FX.
    • Added "razor" insert FX.
    • Added a fifth insert FX slot.
    • The whole FX chain can be saved and loaded.
    • Each effect has a small set of presets, serving as starting points.
  • System
    • Instance
      • Added option for "arp-sync". Defines how the arp plays when releasing all keys.
      • Added "microtuning" option with lots of presets. Can also load any .scl file your throw at it.
    • Preferences
      • Added "unbounded" mouse, which allows adjustments even for values close to screen edges.
Mega fett, damit kriege ich doch perfekt den MALLE Sound hin oder?
Auf jeden Fall mit den Apres-ski Erweiterungen ;)
Mit den enthaltenen fertigen Sequenzen, welche man auch kombinieren kann und den "Production ready" Sounds, schustert man damit in kürzester Zeit was recht Brauchbares zusammen und darum geht es ja überwiegend beim Nexus (Zeitersparnis).
Bevor du dir mit Synthesizern ähnliche Sounds gebastelt hast usw., hast du mit Nexus schon dein Album fertig :D
Ich weiß nicht so recht; sicherlich eine Reaktion auf den umlaufenden C***k. Hat ein komisches Geschmäckle. Meiner Meinung nach sind es 99 EUR für eine Aktualisierung des Kopierschutzes.
Im X-Mas-Sale wollte ich mir ursprünglich die neue Piano Expansion gönnen. Stattdessen werden es nun 3 Flaschen Mirabellenschnaps. Hält wahrscheinlich ähnlich lange wie Nexus 4.
Bis ich mich durch das Complete durchgeskippt habe sind mindestens zehn Jahre ins Land gegangen.
Grundsätzlich besteht ja kein Grund sich "Complete" zu holen, auch wenn man vielleicht z.B. manche Hiphop Sounds auch im z.B. EDM gebrauchen könnte. Ich selbst brauche kein "Bigtone", "Dubstep", "Psytrance", "Trap" usw., aber ich mag z.B. die "XP Sound of the 80s", oder die Hollywood Dinger. Und dann hält sich die Anzahl der Presets eigentlich gut in Grenzen.
Erst neulich sah ich im Internet eine Preset Packung für nen anderen Synth "9000 Presets", da bekommt man natürlich ne Macke, ich frag mich wer so was braucht, nutzt, will...da würde ich auch nicht durchblicken.
Ist mit anderen Sachen so ähnlich, manche horten z.B. Drumsamples, aber wie viele Bassdrums, Snares usw. braucht man im Leben?
new:
  • Front panel
  • Librarian
  • Arpeggiator
  • Modulation
  • Effects
  • System
    • Instance
    • Preferences
danke.
99 klingt zwar verlockend, aber die Änderungen sind mir persönlich auch nicht so wichtig. Ist ja eher ein Nexus 3.5
