Neue Line 6 Helix Firmware 2.50
SteKrae
SteKrae
Line 6 hat heute die neue Firmware 2.50 für Helix Floor, Rack/Control und LT veröffentlicht. Neben 2 neuen Ampmodellen und der Übernahme aller Effekte aus den alten M13, M9, M5, DL4, DM4, FM4 und MM4 Pedalen sind vor allem die neuen HX Reverbs hervorzuheben.
Gleichzeitig wurde Helix Native auf die Version 1.50 geupdatet und hat dieselben Amps und Effekte erhalten.
Von der Line 6 Homepage:
Helix Firmware 2.50 (Helix Floor, Rack/Control, LT)
New Amps (2)
  • Cali Texas Ch2, based on* the drive channel of the MESA/Boogie® Lonestar (Ch1 coming later)
  • Placater Dirty, based on* the BE/HBE channel of the Friedman BE-100 (Clean channel coming later)
* All product names are trademarks of their respective owners, which are in no way associated or affiliated with Line 6.
New HX Effects (6)
  • Delay > Multi Pass (Mono, Stereo), Line 6 Original bandpass-filtered multitap delay
  • Reverb > Glitz (Mono, Stereo), Line 6 Original
  • Reverb > Ganymede (Mono, Stereo), Line 6 Original
  • Reverb > Searchlights (Mono, Stereo), Line 6 Original
  • Reverb > Plateaux (Mono, Stereo), Line 6 Original
  • Reverb > Double Tank (Mono, Stereo), Line 6 Original
New Legacy Effects (77)
Helix Floor, Rack/Control, and LT now include a library of effects from M13, M9, M5, DL4, DM4, FM4, and MM4. These appear in a new "Legacy" subcategory in the model list.
  • Distortion > Tube Drive
  • Distortion > Screamer
  • Distortion > Overdrive
  • Distortion > Classic Dist
  • Distortion > Heavy Dist
  • Distortion > Colordrive
  • Distortion > Buzz Saw
  • Distortion > Facial Fuzz
  • Distortion > Jumbo Fuzz
  • Distortion > Fuzz Pi
  • Distortion > Jet Fuzz
  • Distortion > Line 6 Drive
  • Distortion > Line 6 Distortion
  • Distortion > Sub Oct Fuzz
  • Distortion > Octave Fuzz
  • Dynamics > Tube Comp
  • Dynamics > Red Comp
  • Dynamics > Blue Comp
  • Dynamics > Blue Comp Treb
  • Dynamics > Vetta Comp
  • Dynamics > Vetta Juice
  • Dynamics > Boost Comp
  • Modulation > Pattern Tremolo
  • Modulation > Panner
  • Modulation > Bias Tremolo
  • Modulation > Opto Tremolo
  • Modulation > Script Phase
  • Modulation > Panned Phaser
  • Modulation > Barberpole
  • Modulation > Dual Phaser
  • Modulation > U-Vibe
  • Modulation > Phaser
  • Modulation > Pitch Vibrato
  • Modulation > Dimension
  • Modulation > Analog Chorus
  • Modulation > Tri Chorus
  • Modulation > Analog Flanger
  • Modulation > Jet Flanger
  • Modulation > AC Flanger
  • Modulation > 80A Flanger
  • Modulation > Frequency Shift
  • Modulation > Ring Modulator
  • Modulation > Rotary Drum
  • Modulation > Rotary Drm/Horn
  • Delay > Ping Pong
  • Delay > Dynamic
  • Delay > Stereo
  • Delay > Digital
  • Delay > Dig w/ Mod
  • Delay > Reverse
  • Delay > Lo Res
  • Delay > Tube Echo
  • Delay > Tape Echo
  • Delay > Sweep Echo
  • Delay > Echo Platter
  • Delay > Analog Echo
  • Delay > Analog w/ Mod
  • Delay > Auto-Volume Echo
  • Delay > Multi-Head
  • Pitch/Synth > Bass Octaver
  • Pitch/Synth > Smart Harmony
  • Pitch/Synth > Octi Synth
  • Pitch/Synth > Synth O Matic
  • Pitch/Synth > Attack Synth
  • Pitch/Synth > Synth String
  • Pitch/Synth > Growler
  • Filter > Voice Box
  • Filter > V Tron
  • Filter > Q Filter
  • Filter > Seeker
  • Filter > Obi Wah
  • Filter > Tron Up
  • Filter > Tron Down
  • Filter > Throbber
  • Filter > Slow Filter
  • Filter > Spin Cycle
  • Filter > Comet Trails
Improvements/Changes
  • If a Snapshot has been given a custom switch color, that switch ring now displays a dim color when not active
  • 12 of Helix's 17 reverbs originally appeared in M-Class processors and Verbzilla. As such, they've been moved into the new Legacy subcategory within the Reverb category
  • Helix's tempo no longer responds to pressing TAP at tempi lower than 40.0 BPM (Beats Per Minute). This is to ensure that multiple fast tap entries are recognized properly, as previously, they could be seen as one really slow tap entry. You may still manually select a tempo all the way down to 20.0 BPM and your presets can still be saved with tempi down to 20.0 BPM just touch TAP and turn Knob 6 (BPM)
