korg hat den nucleus angekündigt!!
64 stimmen
3osc +sub
MS20/TB/Jupiter8/Moog/Oberheim selbst ostzilierende [g=43]filter[/g]..
- 8 x part multitimbral and/or combis
- 64 note polyphony
- 3 x Oscs, and 1 x Sub
- A new [g=43]filter[/g] arrangement consisting of three filters per part configurable in Single, Series, Parallel, Series/Parallel hybrid, Dual-Split and Tri-Split modes
- MS20/TB/Jupiter8/Moog/Oberheim-emulated self-oscillating filters, with selectable 1-to-6 poles, with additional tube saturation, tape saturation, and/or wave-shaping processing
- Additional [g=23]distortion[/g]/overdrive/valve-emulation/wave-shaping per part
- 4 x LFOs with customisable/importable waveforms. Can also be used as 1-shot EGs
- 4 x EGs, two of which have 8-stages. All EGs have selectable Attack/Decay/Release curves
- 2 x Step/Karma sequencers per part
- 3 x Modulation sequencers per part
- Interpolation/smoothing between knob values, avoiding 'stepping' between discrete [g=32]MIDI[/g]/knob values
- Up to 16-voice [g=7]patch[/g] unison with panoramic spread
- 100 Comprehensive multi-timbral effects and algorithms
- Standard subtractive
- Wavetable & vector waveshaping synthesis
- Full Frequency Modulation
- Oscillator-sync, Cross/Ring-mod
- Formant/Vocoding modelling
- Retro 8-bit synthesis/emulation including C64 SID synthesis, wave-sequencing, and individual oscillator sequencing and modulation per oscillator
- Granular synthesis with compreshensive [g=23]distortion[/g] and wave-shaping
- UniOsc - upto 11-[g=90]voices[/g] stacked using 1-note polyphony
PCM/Waves
- 256 PCMs and wavetables sampled MS-20, PolySix, Pro-1, MiniMoog, TB303, Juno106, SH-101, Jupiter 8, Evolver, and many more...
- [g=89]VSTi[/g] functionality with sound-librarian
- Firewire transfer of digital output/input audio + [g=32]midi[/g]
- 4-stereo (8-mono) x 24-bit ¼'-jack-socket balanceable outputs
- Oscilloscope display for monitoring waveforms in realtime via TouchView menu
- Unobtrusive carry handle inset (flush) with/into rear-panel
- DVI/VGA output 'add-on option' to display screen on a PC [g=226]monitor[/g]
- 4 x Karma phrase-[g=1]arpeggiator[/g]/step-[g=70]sequencer[/g] with ability to import/program user-arp's
- User-importable 'boot-up' screen visual-image greeting with user name-tag
