kerninger
Flötenspieler
Es gibt wohl ein neues Plugin von Newfangled Audio. Einführungskurs 49$.
www.newfangledaudio.com
Here’s a little secret: compression, limiting, and overdrive are all the same thing—and all of them can be used to add energy and excitement to your music. Invigorate is a deconstructed compressor, limiter, and overdrive distortion fine-tuned to add life to your mix, drum bus, or any other element. The intuitive design allows you to effortlessly morph from pumping compression, through hard-hitting limiting, to rich distortion while dialing in the perfect sound with the prominent MIX control. The result is guaranteed to bring your mix forward and make it sound bigger.
Invigorate | website
