ZITAT:
current software version is V1.06 V1.06 of the Nord Lead 2/[g=211]Rack[/g] 2 software features the following compared to V1.04:
* Fixed: Sometimes the [g=3]DSP[/g]\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'s would not start in sync, which would result in some [g=90]voices[/g] appearing at the wrong output. Now they will start together and all [g=90]voices[/g] will appear at the correct output.
* Fixed: No bank select would be sent when changing program or performance between banks. Now bank change is always sent, for program change and performance change. Bank select is also received.
* Fixed: Sound on SRAM card 1.1 to 1.11 would overwrite performance 1.F4 to 1.F6 and vice versa. Now 1.1 to 1.11 have there own memory space on the card. Version 1.06 will read old cards, but 1.1 to 1.11 will be garbage. If the sounds 1.1 to 1.11 are fine on the old card, one can save them in internal memory with the old version (<1.06) and then change to 1.06, and then copy them back to 1.1 to 1.11. <(li>
* Fixed: When the keyboard was in octave shift mode (4 out of 5 LED's lit), the [g=32]MIDI[/g] [g=190]channel[/g] could suddenly change. Now it will always be the [g=190]channel[/g] chosen for the active slot.
