InstantMappings HowTo
With the file 'UserConfiguration.txt'provided in
this directory, you can create your own Instant
Mappings.
Note: Since this mechanism relies on the scripts
added for Live 6, you can solely map the given
functions to your Control Surface. You can neither
add functions nor can you change the banks of
device parameters.
1. Create a directory in 'User Remote Scripts'.
The name of the directory will show up in the
list of Control Surfaces in Live.
Naming: The name of the directory should not
start with '_' or '.'.
2. Copy the the file 'UserConfiguration.txt' into
your directory. The name of the file needs to
remain unchanged.
3. Edit the copy to adapt it to your needs. The
comments in the file will tell you what to do.
