R
rasputin555
Hi you guys!
I got a Regelwerk these days. I want to use it as a controller for vsts in ableton live. Therefore i want to activate an [g=77]vst[/g] effect by pressing one of the 24 buttons and deactivate it by pushing it once again. THE LED SHOULD BE LIT DURING ACTIVATION AND SHOULD BE TURNED OFF WHEN DEACTIVATED. So far, sounds simple.
BUT i only figured out the toggle mode n the momentary mode, which both are not what i am looking for:
in toggle mode, i would need a configuration that deactivates an [g=77]vst[/g] effect when deactivating the [g=32]midi[/g]-events. As it is by now i have to push the button TWICE for activation and TWICE for deactivation;
Button/led ON - effect on, [g=32]midi[/g] on
OFF - effect on, [g=32]midi[/g] off
ON - effect off, [g=32]midi[/g] on
OF - effect on, [g=32]midi[/g] off
Im momentay mode i have to press it only once, but the led is lit only when holding it down. In this mode the effect should be activated only for holding the button down, but it activates/deactivates the effect every time you push, not while holding it down.
PLEASE HELP
THANKX
Thomas Galad
PLEASE HELP
THANKX
Thomas Galad
