Audio Assault Ultimate Bundle $59.99
Bitte nicht zu viel viel dazu schreiben, das überfordert mein kleines Gehirn immer. Danke.
Was gibts da groß zu schreiben? SALE SALE SALE!!!!!!!!!!!! Plugins billig! Klicken und kaufen. So einfach.
hö, was ist daran jetzt so schwer den link zu klicken?
Ein Klick, da haste alles aufgelistet!
Oder hab ich nicht mitbekommen, dass Hinweise hier jetzt immer mit persönlichen Rezensionen unterlegt sein müssen?
aber bitte, für Klickfaule:
the Ultimate Bundle is the perfect arsenal for a perfect mix, includes 10 plug-ins including
Amp Simulators, Grind Machine ll and 2 add-ons, a Drum Kit, The Transient Pack, EQ and Saturators. With a value of over $300, This is the better way to purchase mix weapons from Audio Assault.
Grind Machine ll
Grind Machine II is the reincarnation of our legendary metal tone monster “Grind Machine”! Reconstructed from the ground up, Grind Machine II delivers a streamlined workflow and improved realism!
Our proprietary IMPACT engine emulates the microdynamic movements of real speakers, adding a sense of realism not commonly found in amp modelers. The included assortment of brutal amps can be paired with the included cabinet collection, allowing you to hone your perfect tone quickly!
Dirt Machine
Built on the same engine as our highly acclaimed “Grind Machine II”, “Dirt Machine” gives you all the controls you wish you had on your favorite drive boxes with a no-nonsense workflow!
Dominator & Emperor
Our amplifier series, each of which brings a full guitar rig into one easy to use plugin! They delivers a range of tones inspired by a legendary high gain amps that is praised by guitarists of many genres!
Combined with a flexible pedal board and effects loop, as well as our Virtual Cabinet with optional IR loader, Dominator, Bulldozer & Emperor makes it easy to craft the perfect tone quickly!
Druminator
Includes a full range of mixing tools & effects on every channel to adjust the way the microphones affect the signal, compress, transient design and shape the drums the way you need to.
XCTR
Is a multi band saturation unit that harnesses the power of Head Crusher so you can target specific frequencies with saturation and excitement! Phatten up the bass, smooth out the midrange, add air, it’s all possible from one interface! XCTR is equally at home on individual tracks and on instrument busses, or even in parallel!
FreakQ 305
FreakQ is an analog inspired non-linear equalizer that embraces the power of your DAW while delivering the sheen and warmth of analog!
This equalizer allows you to sculpt and shape your tones in unheard of ways to create something truly unique! Focusing on delivering the flavor of analog without the noise, FreakQ 305 does not model any specific piece of analog hardware.
Rather, the focus is on bringing the familiar workflow and harmonic brilliance of analog EQ’s into your DAW while adding some unique features that make it one of a kind!
Multi Transient
Multi Transient is a multi band transient designer that gives you complete control over the shape of your tracks! Multi Transient isolates the transients of your audio and allows you to control the intensity of the transient and of the sustain! It’s multi band design allows you to fine tune where in the spectrum the attack and sustain should be shaped!
The Punch
The Punch is your new secret weapon for adding impact and dimensionality to everything from drums to full mixes!
The Punch emphasizes transients while sculpting away boxiness to bring a concussive blast to your mixes!
This plugin has only one control, allowing you to dial in just the right amount of the effect.
Try it on all kinds of sources!
Transient+
Tighten up a tubby kick drum, remove unwanted room tone, emphasize
the decay of your toms, transform guitar DI’s, add brilliance
to a vocal, and so much more!
Discharge & Dominator Cabs Expansion Packs
Amps and IRs for Grind Machine II
Grind Machine ll
Dirt Machine
Dominator & Emperor
Druminator
XCTR
FreakQ 305
Multi Transient
The Punch
Transient+
Ich gehe ja immer noch davon aus, in meinem evtl. Etwas naiven besagten Denkaparat, das hier nur die Deals verlinkt werden von denen man aus irgend einem Grund selber überzeugt ist.
Z.b. Weil man Erfahrungen mit der Firma hat oder besagte Plugins selber besitzt und für gut befunden hat.
Sowas wär dann natürlich enorm hilfreich für andere User zu hören, das warum.
Grind Machine ll
Dirt Machine
Dominator & Emperor
Druminator
XCTR
FreakQ 305
Multi Transient
The Punch
Transient+
ist doch alles subjektiv, ich nutze den Dominator nur zum Verzerren von Acidbasslines, dafür ist das Teil aber eigentlich nicht gedacht, hilft das jetzt wem weiter? Da ich schon viel gutes auch von dem Zeugs sonst noch gelesen habe, dachte ich, jemand wartet evtl. auf soetwas, ich bin immer dankbar, das ist zZ. nämlich der einzige Fred weshalb ich hier noch herkomme.
Wenn ich jetzt immer groß Aufwand machen soll, dann rezipiere ich lieber nur!
Grad auch nochmal in andere Hinweise hier geschaut, das ist auch nicht mehr im Endeffekt und die werden auch nicht gleich blöd angemacht.
