Newfangled Audio Pendulate [FREE]
mkzwoo
mkzwoo
FREE CHAOTIC MONOSYNTH
Bored of the same old synth sounds? Newfangled Audio's Pendulate is refreshingly different. Pendulate is a chaotic monosynth that uses a brand new double-pendulum-oscillator to create previously unheard sounds - biting basses, searing leads, and gritty textures. It can smoothly fade from a sine wave to total chaos, with an expanse of territory to explore in between.
CREATE THE CHAOS
Pendulate’s chaotic oscillator is based on the physics of a double pendulum. What initially looks like randomness contains underlying patterns, interconnectedness, constant feedback loops, repetition, self-similarity, fractals, and self-organization. When designing the Pendulate oscillator we took great care to bring out these underlying patterns to create something both chaotic and musical.
FEATURES
  • Novel chaotic oscillator based on the double pendulum makes sounds you’ve never heard before, but will want to hear again
  • Wavefolder based on the one in the Buchla 259 Complex Waveform Generator, adding MIX and CUTOFF
  • Low Pass Gate based on the Buchla 292 adds controls for POLES and RESONANCE
  • Innovative modulation UI allows modulation over every control from the main page, allowing up to 325 simultaneous modulation routings
  • MPE support allows amazing control from innovative new controllers
  • Looping Envelope and LFO each have multiple outputs generated at once, and can modulate each other, like a modular synth
  • Modulation! Every mod output to every control means up to 325 modulation points in an intuitive single pane
  • Animations! The Double Pendulum, Wavefolder, and Low Pass Gate modules each have animations to show how each module responds to your input, and to modulation
  • Fully resizable UI!
  • Intuitive Midi Learn functionality allows you to assign MIDI CCs to any control with just a click
  • Three unique color schemes to customize your look
  • 136 Presets including artist presets from Matt Lange and Matthew Wang
Der ist aber schon immer free gewesen und daher kein Schnäppchen. Vielleicht müssen wir eine free Sektion einführen, wenn das hier so weiter geht.
Stimmt, du hast Recht....
Hier findet ihr aktuelle Sonderangebote und Rabatt-Aktionen und könnt auf ebensolche hinweisen
Und ebensolche gehören dazu... Oder ganz anders, Du wirst als MOD in der Free Sektion eingesetzt... Also ich wäre dafür, wer noch?
Etwas das free ist muss man echt nicht in Deal of the day unterbringen. Das müllt hier nur zu.
Da würde doch eine FREE-Thread Abhilfe schaffen.
Allerdings gibt's ja auch manchmal Gratis-Sachen von größeren Herstellern wie Waves oder Soundtoys, will man die da mit reinschmeißen? Bin da gespalten
Ich wäre für eine generelle Free Ecke, da kommt nur Freeware rein und die bisherige, da kommen alle Schnäppchen, Introsales, Introfreebies und Sachen, die generell nur befristet free sind rein.
Jo, wäre gut. Dann kann man auch so Best free Synthies, best free EQs, best free reverbs Threads aufmachen da drin. Gibt ja durchaus richtige Perlen.
Aus meiner Sicht ist der Pendulate eine solche Perle. Für krassere experimentelle Sounds im Free-Bereich einer der besten.
Naja, im Grunde genommen sind ja gratis Instrumente und Effekte ein Thema für Hardware- und Softwarenews, da die ja ihren Status (kostenlos) immer beibhalten und daher gleichwertig mit kostenpflichtigen Softwareprodukten sind; also anders formuliert: nichts besonderes.
Es wäre natürlich trotzdem cool einen Ort zu haben, an dem sich diese Sachen sammeln, damit man immer mal nachschauen kann. Ob das eine ganze Sektion würdig ist halte Ich für fragwürdig. Aber definitiv bei Deal-Of-The-Day anpinnwürdig, weil man dann eventuell auch mal was gratis nimmt, bevor man kauft.
Ja schon klar aber für die anderen Plugins müsste ich scrollen
Eine Zeile, ja.
Ich rede übrigens nur von 'nem Sammelthread, nicht von den individuellen Angeboten. Also einem FREE-Thread, in den alles rein kann. Müsste theoretisch nicht mal angepinnt sein, aber so würde es dann erstmal jeder sehen.
Introsong
TheSarge
TheSarge
mkzwoo
notebynote
notebynote
emulator
Glutamatjunkie
Glutamatjunkie
