Hier:
www.waves.com
The new version of the plugin, Scheps Omni Channel 2, expands the palette into new sonic territories.
The new features include: CRUSH, a fourth saturation flavor for aggressive distortion. SOFT, a new soft-knee compressor, in addition to the Omni’s VCA, FET, and OPT. A new 24dB-per-octave filter with serious resonance, perfect for creative effects such as filter sweeps. Plus, the ability to host absolutely any VST3 plugin, by any manufacturer, in the Omni’s insert point, in order to add any effect to the Omni signal flow.
Unter anderem kann das Plugin jetzt auch third party VST3 plugins "hosten". Und wenn ich den Screenshot richtig deute, dann scheint das sogar in DAWs zu funktionieren, die (auf MAC) nur AU Plugins aufnehmen. Das wäre cool - hier in Logic:
Scheps Omni Channel 2 – Channel Strip Plugin - Waves Audio
The perfect channel strip, designed with Grammy-winning mixer Andrew Scheps, to deliver his time-tested combinations of compression, EQ, saturation, de-essing and more. Now expanded with brand new features.
- 5 modules for preamp color, EQ, de-essing, compression, gating
- Choose from 4 analog preamp saturation colors with filtering
- Choose from 4 compression options with easy A/B/C/D comparison
- DS2 dual de-esser goes beyond conventional sibilance control
- Re-order the channel strip’s signal chain order however you want
- Internal and external sidechains with filters
- 250 presets by Andrew Scheps, plus more Grammy-winning mixers
- Andrew’s FOCUS presets help you focus on key controls for your mix
- Host any VST3 plugin (Waves or other brands) in Omni’s “Insert”
- Internal MS, Duo, Stereo routing per module
- Zero latency, perfect for mixing in the studio and live
