Sylenth 1 Easter Sale
  • Ersteller Rec0rder
Rec0rder
Rec0rder
Island of Gods
hatten wir schon?
alltimeclassic superjuice Synth
Easter Sale mit 20%
From the 9th to the 16th of April 2020 we will be offering 20% discount* on Sylenth1 in our Easter sale!
To activate the discount, just visit our webstore and enter the coupon code EASTER2020 during the order process.
Sylenth1 is a virtual analog VSTi synthesizer that takes the definitions of quality and performance to a higher level. Until now only very few software synthesizers have been able to stand up to the sound quality standards of hardware synths. Sylenth1 is one that does.
Sylenth1 is not just another synth. It was built from a producer's point of view. It was built to produce superior quality sound and music. It was built to perform. A lot of research has been invested in order to achieve unheard warmth and clarity. The graphical interface ensures the highest level of usability so you can fully unleash your creativity.
Oscillators
At its core Sylenth1 houses 4 alias-free unison oscillators, which generate analog shaped waveforms. Each oscillator is capable of producing 8 unison voices in full stereo, adding up to a total of 32 voices per note. With its 16 notes of polyphony this means you can play up to 512 voices simultaneously! The oscillators perform extremely well in both the very low (down to 0.01Hz and below!) and very high (all the way up to half the samplerate) frequency regions without losing their sharpness, liveliness or character. This makes them well suited for all kinds of sounds, from the deepest basses imaginable to the highest crystal clear bells.
Filters
On top of that there are 2 state of the art, pure analog sounding filter sections. Each of these consists of 4 filter stages with nonlinear saturation incorporated, in order to emulate the warmth and drive of a real analog filter. The resonance control can be turned up to a level way beyond self-oscillation and combined with the drive control this makes it possible to let the filters SCREAM! Where a lot of digital filters sound like they're made out of cheap plastic, these filters sound rock-solid, warm and raw.
Modulation
Sylenth offers many modulation options to sculpture the sound any way you like. There are 2 ADSR envelopes and 2 LFO's which can be used to modulate a whole set of different parameters. Next to that, it is possible to use the extra 2 amplitude envelopes, velocity, keyboard track or modulation wheel as a source for modulation.
Master FX
The final part of this synth is the master effects section. A set of 7 professional quality sound effects and an arpeggiator, conveniently grouped into an LCD panel structure.
  • Arpeggiator – 10 different melodic modes, built-in step sequencer with adjustable pitch, velocity and hold settings. Outputs Step Velocity as a modulation source.
  • Distortion - Five different types of distortion (overdrive, foldback, clip, decimator and bitcrusher) in full stereo, uses 4x oversampling to minimize aliasing artifacts.
  • Phaser - 6-Stage stereo phaser, with 2x oversampling, an embedded LFO, feedback and frequency spread adjustment.
  • Chorus/Flanger – 4-Stage stereo chorus, with 2x oversampling, adjustable delay time, depth, rate and feedback for flanging effects.
  • Equalizer - Bass and treble adjustment by frequency and amplification.
  • Delay - Delay module with low and high pass filters, unique echo smearing function, pingpong mode with stereo spreading, independent left and right delay time and adjustable stereo width.
  • Reverb - Smooth reverb with adjustable pre-delay, damp, size and stereo width.
  • Compressor - Stereo compressor with attack, release, threshold and ratio settings, which can be used to increase punch, drive, warmth and analog feel of your sounds.
Performance
With all the functionality and processing horsepower mentioned above, you might expect that this synth would max out even the fastest CPU in no-time, especially considering the high sound quality of each single voice and effect. Well, one of the many benefits of this synth is that it doesn't. It uses highly optimized code and SSE instructions in order to reduce the CPU usage to a minimum. It will also automatically turn off any parts that are not used, to save extra CPU time. This enables you to create pure quality sound using only minimal system resources.
Ich fand den mal richtig gut und hab ihn doch noch nie benutzt.
Reaktionen: CFR
Ich glaube Hive, Serum, Dune und Spire haben ihm den Rang abgelaufen!...
Reaktionen: CFR
Denke auch, dass die Zeiten für Sylenth abgelaufen sind. Die Konkurrenz ist groß. Oder sogar größer.
Edit, oha... deren Homepage ist seit dem Jahre 2007, dem V1 Release Jahr vom Sylenth, ebenfalls unverändert.
Der hat nur dieses eine VSTi auf den Markt geworden. Danach nix mehr. Schade.
Ich glaube das Teil lebt vorallem davon, dass es zich Tutorials zu dem Teil bei Youtube gibt. Fast immer wenn ich gucke, wie andere Leute einen bestimmten Sound gebaut haben, ist der mit dabei.
Er bietet zwar nur eingeschränkte Syntheseformen im Gegensatz zu heutigen Konkurrenten, aber VA ist nun ja nicht "out" und
man braucht sicher nicht immer Wavetable und Co. Der Synth lässt sich easy bedienen, klingt nach wie vor gut und es gibt
vermutlich Millionen Presets, die auch zum verändern und selber schrauben einladen. Er gehört immer noch zu meinen Favoriten.
Als Auslaufprodukt sehe ich ihn noch nicht, ganz im Gegenteil ist er sicher noch bei vielen populär.
Sylenth verwende ich in jeder Produktion.
Frisst keine CPU und ist mit 4 Oszillatoren auch sehr flexibel.
Spire, Hive, Dune und Serum konnten mich nicht überzeugen umzusteigen.
Strobe 2 ist mein Buddy neben Sylenth.
Der Rest kommt dann aus Bitwig.
Ein besserer Browser könnte Sylenth aber mal gebrauchen.
Genau so macht man das:cool: User möchten bzw sollten nix anderes, neues haben wenn alles perfekt sitzt
Das soll mal ein anderer Hersteller schaffen.
Der Sylenth begleitet mich zb schon seeeeeeehr viele Jahre und wird es bis ans Ende tun, vorrausgesetzt
die kommen nicht mit einem alles neu Instagram Influencer Update incl. Bugs an
MassiveX anyone?
Massive X habe ich auch wegen Komplete.
Finde ich zum Schrauben auch gut.
Einzig was mir fehlt: ein EMS.
Der von Arturia Synth V habe ich im Auge.
Ich kenn den Sylenth auch sehr gut, Kollege nimmt den. Ich aber mag den nicht so. Sylenth klingt immer sehr nach Dance. (die meisten Sounds werden dafür ja programmiert, welch Wunder ;) ) Klar, der kann auch anders, weiss ich... Hm, also mich langweilen reine Analog-clone vielfach. Daher wohl. Schlecht ist der Sylenth natürlich nicht, bitte nicht falsch verstehen. Trotzdem null Entwicklung bei Lennar Digital. Das ist halt schade, man hat den Eindruck, dass das nicht mehr gut läuft. Und was, wenn der Laden plötzlich in die Isolvenz geht. Da ist doch iwie was faul, alleine die ungepflegte Homepage. Nur so ein merkwürdiges Gefühl, egal. Kauft ihn!
Fuer 140 Tacken ist der maximal ueberteuert, wenn man den mit anderen Kandidaten vergleicht die mehr koennen und dabei WEITAUS weniger kosten, wie z.B. A.N.A und Synthmaster One.
Fuer 30 haette ich den genommen, fuer mehr nicht.
Sylenth läuft stabil, viele andere nicht. Dafür bezahlt man gerne
...bei wie vielen wohl steht:"Licensed to Team...R2R, AIR oder ASSiGN!?
ja. So wie einst beim weltberühmten Dance-Producer Avicii (RIP), das konnte man sogar gut in YT Videos sehen, als er seine Tracks vorführte. Als der Shitstorm somit begann, hat er dann doch noch eine echte käuflich erworbene Sylenth Lizenz erworben. So kann es also auch gehen...
denke auch, dass sylenth immer noch ein sehr guter und vor allem superleicht bedienbarer synth ist.
Welche laufen denn nicht und welche sind denn nicht stabil? Was sind viele?
Bei ANA hatte ich oft das Problem das die Presets nicht mitgespeichert werden, wenn ich ein Projekt speichere.
Xils Lab lies damals immer Logic crashen.
Der KVR Mist lief auch noch nie ohne zu crashen.
Eine zeit lang war Zebra ein Problem.
Ach ich habe das meiste wieder verkauft.
Bei Sylenth gibt es keine Probleme. Läuft stabil und frisst keine CPU.
Danke dir, interessant! Davon habe ich (noch) nichts. Vielleicht dann ja zum Glück. Aber vermisse das auch iwie nicht, man hat ja, was man hat.
Das stimmt! hier auf Win war das. Aktuelle Version aber ok soweit. Bin aber jetzt eh lieber auf dem modularen Melda MSF.
hm. ob ich den dann doch nochmal anchecken sollte. ;)
CPU-hungriger Stuff fliegt bei mir nämlich rigoros raus. Trotz aktuellem hochleistungsfähigem Rechner.
Also meine Xils Lab Erfahrungen liegen schon viele Jahre zurück. 2012 oder so.
Aber Xils waren neben EMS die ersten die einen EMS/AKS Synth als Plugin lieferten.
Nun, mit Arturia Synth V hat sich das wohl erledigt, man kann ausweichen.
Klanglich war das Teil aber von Xils gut....Ist ja schon Version 4 draußen.
ANA habe ich noch. Aber so richtig warm werde ich damit nicht. Marktplatz?
So denke ich auch. Es ist ok wenn man einen Synth hat der etwas spezielles kann was andere nicht können, aber
für die meisten Sounds kommt man mit fast jedem Synth hin.
CPU Belastung ist wirklich ein Traum bei dem Teil, ebenso wie beim DUNE3. Für Sylenth gibt es eben ohne Ende Sounds im Netz. Ich denke für alle die nicht so gerne schrauben ist das schon ein Argument.
Ich fahre derzeit total auf den Cubase Onboard Retrologue ab. Völlig unterschätzt der gute Stück.
