Gast92251
Guest
Ein Hinweis, auf Gearslutz gefunden,
einige wenige hatten Probleme beim Beenden von Cubase 8.0.20 :
barryfell worte:
" know quite a few people have a problem with Cubase crashing/hanging on exit. I've had it for a long time, and it's existed on all versions of 8 for me, but I finally found a fix.
A lot of people have said it's due to Waves, Slate or others plugins, and suggest trying latest versions of them etc, but i've found that doing a repair install of Cubase fixes the problem. So far it's been a week of busy projects using plugins from the likes of Waves and Slate and i've not had one crash on exit.
Either run the Cubase installer again, and it will give you the option to 'repair', or use a program like CCleaner, which will give you access to the same installation dialog when you choose Cubase from the list of installed programs it shows... "
aus: https://www.gearslutz.com/board/cubase-pro-8/1012919-cubase-crashing-exit-fixed.html
Und hier was anderes zum Thema aus dem Steinberg-Forum:
"maaaaaybe, this method can be applied to ANY AND ALL misbehaving vsts crashing etc..-
(havent tested with other crashy vsts-... yet
Windows:
GOTO: Registry Editor.
Navigate to HKEY_CURRENT_USER\Software\FabFilter. (<<< DWORD (32-bit) Value.
Name it GraphicsAcceleration and ensure its value is set to 0.
Mac OS X: Open Terminal and type: defaults write com.fabfilter.Common GraphicsAcceleration 0 (<same deal)
I applied this fix to my cubase folder in registry... ( the actual cubase8 folder, not a vst)
NO MORE CRASH ON EXIT!!!
Ein anderer User antwortete hierauf:
"My dear god man! This actually works!!!
And the program seems faster to boot...
thanks a lot, a whole lot for this!!
aus: http://www.steinberg.net/forums/viewtopic.php?f=226&t=81011
Nur für die, welche davon betroffen sind.
barryfell worte:
Windows:
