Was kommt in FL Studio 5?
  • Ersteller Wordsword
W
Wordsword
gibt es darüber schon Infos was es neues oder verbessertes in der neuen FL Studio Version geben wird?
Tja, es lohnt sich eben ein bissel in den FL-Foren mitzulesen :-D
Aber da kommt einiges auf uns zu:
- Video Player (optional)
- Spline Controller
- DrumSampler Teil
- Timestreching / Pitchschifting Zeugs
- Envelops direkt in der Playist über die Wavs gezeichnet.. (Envelope Controller?)
Aber immer dran denken: das alles gibts erst im September 2069! :p :p :p
Gruss,
rübe & luki
Gerade eben entdeckt:
"What's new in 5.0 ()
New automation clips in playlist.
New powerful [g=1]arpeggiator[/g] tool in piano roll.
New Fruity WaveShaper effect [g=8]plugin[/g].
New option to render audio files with [g=35]slice[/g] markers (regions) built-in (regions are defined as beat markers for Adobe Audition).
Fruity Slicer now gets slices from audio file cue points as well (as well as trigger key #).
Much improved Fruity Slicer, with stretching and REX loops support, and enhanced fill gaps.
New 'make unique' option for audio clips to severe parts.
New time-stretching and pitch-shifting in audio tracks (with several modes, including the Elastique engine).
Tempo-synced preview of stretched samples.
Added author & genre to song properties, saved inside WAV files and [g=114]MP3[/g] tags.
Added tempo detector to audio tracks to align project tempo to song clips.
New drum flam tool in piano roll.
DrumSynth Live now supports 120 patches.
Enhanced Fruity Granulizer with transient-alignment and new skin.
Audio recording can now be undone, and mixer track arming button can be right-clicked not to prompt for a filename.
Added note legato and articulation tool in piano roll.
Added better automation smoothing to [g=32]MIDI[/g] remote control (knob works as 1 pole or 3 poles).
Can now load [g=114]MP3[/g]'s into sampler channels and audio clips.
Setting for steps per beat now adjust tempo as well (no need for tempo-doubling tricks anymore).
Fruity Slicer note dumping is now done in piano roll selection (if any).
New slicing engine in Fruity Slicer and FL (audio clips).
Stacked notes in piano roll randomizer now work better.
Made brush default tool in event editor.
Little bugfix for monophonic mode in step [g=70]sequencer[/g].
Restyled Fruity HTML NoteBook [g=8]plugin[/g].
Background wallpaper can now be HTML pages.
Bugfix in Sytrus (making it a little faster).
Added copy/paste preset to Sytrus, to share presets between all [g=8]plugin[/g] versions of it.
Added global envelope mode to Sytrus (version 1.2), for perfect gated presets.
Fixed crash when deleting [g=32]MIDI[/g] out channels sometimes.
Song markers now properly stored in rendered waves even with tempo changes.
Fixed memory leak in Fruity Slicer [g=8]plugin[/g].
Updated drum list in the [g=32]MIDI[/g] out [g=8]plugin[/g] to the GM2 standard.
Made [g=190]channel[/g] resampling option always enabled.
'Keep on disk' samples can now be modified (loaded from disk when needed).
Can now check 'keep on disk', 'resample' & other options even when not possible.
Newbie enhancement: snapping is off by default.
Can now drop samples onto the [g=190]channel[/g] settings window.
Preview now only loads the few first seconds (for [g=114]MP3[/g]'s to preview faster).
XY controller now supports multiple joysticks.
Right-clicking the recording disk to arm a mixer track won't prompt for a filename.
Added option not to auto-unarm mixer tracks.
Selecting an [g=12]ASIO[/g] input now arms the mixer track automatically.
Added option to trim audio clip parts outside playlist selection.
Auto-envelope cleaning in step edit mode in Sytrus & Fruity Waveshaper envelopes.
Remove transposing from quantization tool - quantization scores can now safely contain notes other than C5.
Toolbars can now be locked.
Replace Ignore velocityy option by Veloccity linkk', to control per-note [g=43]filter[/g] using [g=21]velocity[/g].
Can now shift+click note events to unselect them.
Can now set one of the external audio editors to replace the default one.
[g=32]MIDI[/g] input [g=21]velocity[/g] can now be linked to per-note [g=43]filter[/g] parameters.
Added support for Hercules DJ Console (when set in [g=32]MIDI[/g] mode, endless knobs, coupled switches, special switches & middle jog work).
Added sampler interpolation method selector for realtime playback (audio settings)."
:-o :-o :-o
Quelle: http://www.flstudio.com/misc/whatsnew.doc
ja und wann kommt es nun raus :-? :-?
Jo, das will ich auch wissen.
Sehr begierig bin ich auf Timestretching-Tools in FL, die fehlen mir echt...
(oder gibts sowas etwa in FL 4.5 und ich bin nur zu blöd das zu finden...???)
Generell hoffe ich sehr auf ein baldiges Erscheinungsdatum.
Hmm...
Ich müsste für 29Dullar mal ein Live-Time-Update erwerben.
Die Boxed-Version war eine unglückliche Investition. die Samples sind zu 80% überhaupt nicht mein Ding gewesen.
Wird es wieder son dickes Update Packet geben, oder ist die 5er Version schon wieder ein neues FL Studio?
Eine Time-Strechfunktion gibt es im 4er übrigens nicht...
greez
-E-
Spasti-Clown
[/URL]
@the Emre
also ich denke mal, dass du FL 5 nicht mit dem Lifetimefreeupdate bekommst. Da müssen wir alle wieder bezahlen. Trotzdem, das Geld mit dem Update ist gut investiert. Hatte auch früher die boxed Version
bye
@DJTrancelight
blödsinn ! na klar läuft das unter dem "lifetime free update" !! das gilt solange es das produkt fl studio gibt. ich bin seit version 3.0 zahlender kunde und hab bisher immer meine kostenlosen updates bekommen.
für das wenige geld, die updates, den support und das forum lohnt es sich einfach, sich für das produkt registrieren zu lassen, wenn man ständig damit arbeitet.
@ NOMAX,
und wenn das lifetime Update nur gilt, wenn eine Version 5.2 erscheint und das Update auf 5 trotzdem was kostet?
Nix da! JMC oder Gol meinte sowieso, dass er das Update eher 4.6 oder so nennen würde.. Ausserdem wurde klar gesagt, dass FLS5 (wie jedes Update) unter lifetimefree-updates fällt.
Das war übrigens auch so, als die ProducerEdition eingeführt wurde... (und nebenbei der Name geändert wurde) Auch damals konnte jeder gratis updaten.. Allerdings nicht auf die ProducerEdition.. Das wurde damals ja so gehandhabt, wie ein neuer, und eben optionaler Generator (ala Sytrus, oder der neue Videoplayer wird wohl auch zusätzlich zu erwerben sein..)
Gruss,
rübe & luki
@ruebe
danke !
"FLSTUDIO/FRUITYLOOPS LIFE TIME FREE UPDATES
Customers of the on-line Fruityloops version (not the BOX version, nor the separate plugins) are offered Life Time Free Updates.
This means that whenever a new version of your specific FLStudio/Fruityloops package (Basic, Pro, Full or Producer) comes available, you will have the option to download this new version free of charge.
Image-Line retains the right to decide when and for which specific packages (Basic - Pro - Full - Producer) new versions are released. In no way, can Image-Line be obliged to release new versions."
nach zu lesen unter : http://www.e-officedirect.com/flstudioorder/documents/121.html
@Nomax
wir werden ja sehen... Jedenfalls hört sich das nach einem neuen Versionsprung an zu mal das Handling ganz anders sein soll.
bye
